Old 06-13-2004, 07:03 PM
struttgart struttgart is offline
Question 98 Ford Windstar ABS Problem
Hi,
I am new to this forum and could use some real help with this one.
First, I will give you a little history. My wife and I purchased a 1998 3.8L Ford Windstar three years ago. EArlier this year our ABS light came on and the Ford dealer did a complete rear brake and cylinder (I think that is what they are called?) replacement. During the may long weekend I took the van camping. The brakes worked find on the drive up. It rained all weekend and when I drove it home the brakes were very squishy. I would press the brakes which would work fine but then the pedal would slowly compress to the floor. I took it in to a local mechanic and he told me it was the ABS power unit that was shot and it would be $2500CDN to buy a new part.
Now to my questions. Does this sound right or is the mechanic tryong to hose me? Secondly, is it possible to bypass the ABS all together and return the van to manual braking?
I hope someone can help clarify things a bit for me because I know very little about vehicles.
Ciao,
Cory <((><
Old 06-24-2004, 08:26 AM
DRW1000 DRW1000 is offline
Re: 98 Ford Windstar ABS Problem
Usually when the ABS system is not working and fails its own self test it lights up the amber ABS light and disables the ABS system. Normal braking is not affected. If your Red Brake light is on then your normal brake system has a problem.
Old 06-24-2004, 09:36 AM
ModMech's Avatar
ModMech ModMech is offline
Correct,
And yes, $2500 CDN is WAY too much. The HCUs are only about $900 US, and under $200 for the labor.
Operating a vehicle with ABS that does not work, is NO DIFFERENT than if it were never installed.
Old 12-19-2004, 12:19 AM
i8uiky i8uiky is offline
"I would press the brakes which would work fine but then the pedal would slowly compress to the floor."
this sounds like internal leak in the master cylinder.sounds like you should find a new mechanic
Old 12-20-2004, 12:28 PM
Dngrsone's Avatar
Dngrsone Dngrsone is offline
Send a message via ICQ to Dngrsone Send a message via Yahoo to Dngrsone
Make sure your brake fluid level is all the way to that line.
It could also be something really stupid like the system wasn't bled properly... but it does sound like the master cylinder is leaking.
2003 Ford Expedition 4.6L (Dngrswife's)
2006 Kia Sedona
2008 Toyota Prius (totaled)
1997 Windstar 3.8 liter (retired)
Replaced Head Gaskets
1988 S-10 2.8 liter (retired)
Full Rebuild
