Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-13-2004, 06:58 PM
twizy twizy is offline
Failed emissions in NY, help needed
I recently brought a '00 SH with 64k mi on it. I brought the car to my mechanic and the car failed emissions due to the CO content reading 12.38 gpm, 10 gpm being the limit. He recommended replacing the O2 sensors. I spoke to the original owner and he had never replaced the sensors before. The mods on the car are: Greddy EVO catback, DC header, AEM CAI, and Random-tech high flow catalytic converter. I would be really upset if I spent the $250 parts + $160 labor on replacing the O2 sensors and the car failed again, so I was wondering if anyone failed their emissions and what they did to fix it and pass. Is there anything else besides the O2 sensor that would lower CO content? Thanks !
Old 06-13-2004, 07:46 PM
Loco64670 Loco64670 is offline
Re: Failed emissions in NY, help needed
It could be The High Flow Cat... That May Be The Culprit To Your Car Failing Nueva Emissions
Old 06-13-2004, 09:04 PM
Black92LudeSI Black92LudeSI is offline
Send a message via AIM to Black92LudeSI
go to pep boys, for 10 bucks get this stuff that you put in your gas tank to pass the test. your not to much above the limit
Old 06-13-2004, 09:11 PM
yea it seems other forums agree that it is the catalytic converter, but i was under the impression that random technologies made their converters to be emissions compliant. i guess i will try the emissions fluid and if that doesn't work i'll have to spend the moolah to replace the catalytic converter.... that sux
Old 06-13-2004, 09:23 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
should've kept your stock cat, whenever i add something to my car i keep the original parts just in case.
Old 06-13-2004, 09:26 PM
I woulda kept the stock but I brought the car used with the aftermarket mods already installed, no OEM parts.
Old 06-13-2004, 11:14 PM
soccmid soccmid is offline
Send a message via AIM to soccmid
not ur cat. im sorry its not unless it went bad, because i have a high flow cat from r/t and it actually made me pass emissions. i repleced that and the O2 sensor and yay!. and md emissions are a lot lower than ny's i think our cutoff point is like 8.00 for co2. so unless the cat is bad( tap it see if anything rattles) it isnt teh R/T product.
"You can't do anything worth doing in life without taking a chance" - me
funny shit
Old 06-14-2004, 09:59 AM
88 ROCKET 88 ROCKET is offline
You might want to give the car a "basic" tune up, Distributor, rotor, plugs and wires... and even a new coil. Make sure you get the right plugs, if the fuel/air mix isn't burning completely and clean, you will get carbon and junk on your O2 sensor and fail your smog.
Old 06-14-2004, 06:33 PM
Now that I think about it, could it be the Apexi VAFCII that is disrupting the fuel/air mix and thereby causing the CO to skyrocket? The car has it installed and I have no clue how to operate it. If I reset the ECU will it bring back the original settings for the fuel/air mix? Maybe this + getting the emissions pass fluid will do the trick?
Old 06-14-2004, 07:12 PM
crzyCollegeKid crzyCollegeKid is offline
well, give it a try, keep us posted
Not-named-yet:
2011 Hyundai Sonata SE w/Sunroof and Nav in Iridescent Silver Blue Pearl
Claudia (traded-in):
2003 Mitsubishi Eclipse GTS: Pioneer Speakers All Around, Kenwood MP3 Deck, Clarion Equalizer, Boss 4ch. 800W amp, 2 Dual 12" subs with Dual 500W amp, XM Roady2
R.I.P. Jessica
1997 Honda Prelude: AEM CAI - Exedy Full Face Organic Clutch - XACT Streetlite 12.5lb flywheel - DC Sports Short Throw Adapter
Old 06-15-2004, 07:50 AM
What is a VAFCII?... sorry, I am a back yard mechanic from the 70's/80's
Old 06-15-2004, 02:10 PM
SiGNAL748's Avatar
VTEC/Air/Fuel Controller
Old 06-27-2004, 11:00 AM
update for those still following this thread... i put some of that guaranteed to pass emissions fluid in my gas, and the car passed with flying colors. what a great product.
