shadow help
im in the market for a dodge shadow. i found one for 600 dollars the underbody is very clean and it looks like the person who owned it knew how to take care of it.
thier is a guage going down the side of it from a parking lot idiot, thier is a little bit of fluid comming from the flywheel area and a little comming from the transmission pan. is this a normal thing or does it look like the person beat the car? also any other things to look for when i go back thier?
95 TA - fast 92 240 - fun 96 prelude si - lots o fun 94 cr500r - rediculously fast and fun |
Re: shadow help
also i know that mitsubishi is the saame company so why is it not a popular mod to put in the eclipse motor?
Re: shadow help
Tranny leaks are common and fixable (as long as you don't EVER overtighten) Rear main (oil) seal is harder, but unusual. It may be leeching tranny fluid at the main seal, that's just either a front seal (trans must be removed) or just the pan leak leeching into the bellhousing from driving.
A shadow is NOT a Mitsubishi And is NOT the same company, nor is the motor (thank god) unless you have a 3.0 V6?? which I'm pretty sure was never put in a Shadow... Nice car, but don't expect super performance out of it. Just a decent and reliable simple car. Slantsixness
If I knew what I did to break it, I would've known not to do what I did.www.classicwinnebago.com |
Re: shadow help
i figured it would have been close to the same car because dodge and mitsu did a lot of projects together
Re: shadow help
o ya thanks for the info too
I have a friend with a 3.0L 5-speed Shadow ES. He bought it wrecked and hasn't yet had time to repair it. There are a few of the V6 cars around here, more Dusters that Shadows. They're really fun cars, anyways.
'85 BMW 325e '87 Shelby Lancer #340 '00 Dodge Neon Therefore, having been justified by faith, we have peace with God through our Lord Jesus Christ. (Rom. 5:1) |
ok so i took this shadow out for a ride today and it tapped really bad, is that a common thing with these motors or is this one gone? also how much is a rebuilt turbo motor?
Assuming it has a 4 cyl, did it sound like a deisel? A "knocking" sound that resembles a large truck deisel engine is caused by the sides of the pistons being worn down and slapping back and forth in the cylinders. Engines with piston slap can last indefinitely with minimal oil consumption and no additional problems other than the noise (I know, I had one.) If it had a rod knock, it needs a rebuild; a friend gave me an estimate of about a thousand dollars for a complete 2.2 turbo rebuild.
So is this a turbo car? Or you want to convert it to turbo? Auto or stick? What year is it?
Re: shadow help
it wasn't a turbo but it would have been if the motor wasn't gone
we will keep looking thier will be one out thier
Re: shadow help
Just for info:
Piston slap and broken skirts on 2.2/2.5L motors comes from the car beng beat upon severely, and although it can "hold up forever" like that, the block is usually damaged beyond reasonable rebuilding. It doesn't cost $1000 to rebuild a 2.2 or 2.5, unless it's a turbo, and you are not using stock components. The last 2.5L stock motor I did (May '04) cost a total of $450, including everything (pistons,cam,followers valve job,bearings, rings, gaskets and even a new reman distributor). This is without labor. But you can assemble one in about 2 hours, and remove/install it in about 2 hours (up to 1992 these are not the "new" 2.5L motors). So at $45 a labor hour, you can do one in less than one 8 hour day, at a cost of $450 (plus tax..) and $270 in labor for a grand total of $720. Of course, I do all the labor, and don't charge $45.00 an hour, but I'm not a mechanic and don't own or work at a shop. This is just a hobby for me. Slantsixness
Re: shadow help
wow these engines are that basic that you can just rip it apart and put it back together in a day......
i can't even take out all the bolts on my engine in 2 hours never mind get it out and in again in a day
Re: shadow help
It doesn't have to be complicated to work well.
(unless it's a honda...)
Re: shadow help
ill give honda credit my .5l is rediculously fast and very very powerfull ( it strikes fear in peoples hearts) and its very simple.....
Re: shadow help
you don't have a vtec or a V6... !
