Old 06-13-2004, 03:57 PM
yellowcrxman yellowcrxman is offline
starting problem :( PLEASE HELP
I am having problems starting my CRX. It has a b-16a in it. It is really sparatic, it only does in in the summer, and only when it is really hot(this may just be coincidence, but the fact that it did it last summer, then not at all this winter makes me wonder). I thought it was the distributor cap/rotor/seal. I've replaced the cap, with a 91 Integra RS cap(i was told to replace with a 94 del sol, or 92-93 GSR, but these did not fit. Only the Teg RS fit). I have the rotor on order, but because it had just started up this morning, i would have thought just fixing the cap, and the seal(not the actual seal, just used an O-ring, parts store did not have an actual seal with the cap, guess i'll have to go to the dealer) would have fixed it, but it did not.
So, my question to you guys is: What else besides the distrubitor cap/rotor/seal would be the problem?? What else would be heat related. I really am lost as is my dad and uncle(pretty good with cars). HELP ME! I need to get to work, lol,(and play!!)
Thanks guys
Old 06-14-2004, 11:05 AM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
Re: starting problem :( PLEASE HELP
this might be really wild but have you checked the STARTER??
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 06-14-2004, 01:23 PM
Re: Re: starting problem :( PLEASE HELP
I've had many starters go out on me, NONE like this. Starters don't stop working for a month, then work fine for a whole winter. Thanks for all the help captain ovbious
Old 06-14-2004, 01:26 PM
B1SiR6A's Avatar
B1SiR6A B1SiR6A is offline
Re: Re: Re: starting problem :( PLEASE HELP
haha...touche n00b...good one...
"Check that young man for nitrous"
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Currently 4th in BHRA All Motor Class...Soon to be 2nd (I hope)
...Theres gonna be alotta slow singin, an flower bringin if I hear my car alarm start ringin ...
Old 06-16-2004, 05:29 PM
crxsirpr crxsirpr is offline
main relay, its under the dash, im 99.9% sure its the main relay
Old 06-17-2004, 06:54 PM
Thumbs down Re: starting problem :( PLEASE HELP
Ehhhhhh:Wrong,
It was what I thought it was, the rotor. THanks for all your help guys...
Old 06-19-2004, 02:55 PM
Ehhhhhh:Wrong,
Ehhhh: I was wrong, and dumbfounded.
Put the new rotor on, poof started right up, no probs, could feel the difference in response and power because of the better spark, thought everything was fixed. Now, i've started it up twice, mid-day noon- 4 pm and it won't start, or has a very hard time. I'm 100% sure this is heat related now. I have an O-ring for a seal right now untill I order one from a dealer(the local parts store doesn't have it) But I would think that it would work temporarily and not still cause problems.
I'm lost, would the main relay have problems due to heat? I'm unfamiliar with the main relay so I have no clue. Please help guys, I have shit to do,
Thanks in advance
Old 06-20-2004, 01:42 AM
b16 crx kid's Avatar
b16 crx kid b16 crx kid is offline
ok, this is what u do, when u turn ur car to the on position, before starting it, and all thelights in the gauge cluster go on (check engine light, seatbelt light, etc.) wait for the check engine light to go off then do it. try that and see if it helps.
Old 06-21-2004, 10:15 PM
yep main relay is heat related, in hot days or after a while of runing the car te main relay heats up and doesnt send signal to the fuel ingectors fuel sistem etc. the relay is under the dash in the drivers area under the tach. its a black box the size of a beeper, has 12v stamped in white. change it, it costs around $60 $80 at honda u can get it used for like $20 but wont last as long as the new one. now im 99.99.9% sure its the relay.
Old 06-22-2004, 01:36 PM
Props to CRXSIRPR should have listened to you b4, gonna go get new relay soon. Lately I've been just leaving the windows down, and it hasnt been as hot so it's been starting, thanks man
Old 06-22-2004, 11:42 PM
90tegblackwidow 90tegblackwidow is offline
Yep its the main relay, I have a 90 Integra and I had the same problem. It wouldn't start when the car was hot or warm from driving. I changed my starter and distribitor before finding that out.
Old 06-26-2004, 01:15 PM
ok, nice to know. take care
