Removing ignition switch 1993 Chevy Suburban
I'm having trouble starting my 1993 Chevy Suburban.
Everything seems to be fine except that every day or so I have trouble with what I believe to the the ignition or starter switch or the solenoid? Once contact is made it cranks right up. But somewhere in the key switch is the problem I think. I thought if I could remove the ignition switch I could clean it and it could get better contact. Used to be that I had to turn the key extra far around before contact was made to get it to crank and now I get nothing. Everything seems fine on the rest of the engine I just had a new engine put in and now I believe the starter or ignition is bad. Always something! Can anyone tell me how to take out the ignition switch or if you have another suggestion.
Help!
