Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 06-13-2004, 02:55 PM
utopial2006 utopial2006 is offline
Unhappy Car seems to stall while driving and all cluster lights come on
I just got a new clutch put in my Pontiac Sunfire 95. 113k miles
In a day since i got the car back i started noticing these problems
1> The car does not wantt o start up sometimes (sounds very much like a dead battery but is not thebattery is very strong)
2> The car will jerk while i am driving, all the indicators on the dash will behave like the car is sitting still with the key in the ignition e.g. All the lights will come on .. ABS, Brake, Check Engine, Transmission, etc etc. Speed shown is 0 and the rpms are 0. (all this while iam still moving)
I can keep driving the car with the dash lights on.
Has any one ever experienced this before. Any clue on what may be goign on. Every Thing was perfect before i gave the car to the mechanic for replacing the clutch.
Thanks in advance.
Old 06-16-2004, 11:58 PM
SunChief SunChief is offline
Is it an OEM or performance clutch?
Does your clutch engage with the pedal a lot closer to the floor now?
You might need to have your clutch checked out. I had the same issue once, but I had an APC clutch and it engaged with the pedal a lot lower to the floor than stock. Not sure if this could easily or needed to be adjusted or if it was supposed to be that way. Either way, the stalling issues went away after about 2-3 weeks and the car has been fine since.
"People of the Sun"
