Go Back   Automotive Forums Car Chat > Ford > Contour
Old 06-13-2004, 02:15 PM
crabapple23 crabapple23 is offline
Wacky Contour Problems ~~ Help!
i've got a '96 contour with an automatic tranny. i'm seeing intermittant loss of interior lights, dash lights, radio, etc., check battery light comes on intermittantly as well. also, the "overdrive is off" light flashes continuously and i lose engine power occasionally. anyone have any idea what might be causing any/all of this?
Old 06-13-2004, 05:54 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Wacky Contour Problems ~~ Help!
Overdrive light, is probably the speed sensor is going, Mine started flashing yesterday. But when I turned off the car it went off. But the speed sensor did go on my car a few years back, And the OD light was flashing then too. I have no clue about the dash lights.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 06-18-2004, 12:45 PM
rruddfan21 rruddfan21 is offline
do you have any other problems with headlights, radio, etc? stab in the dark here but maybe you should check the alternator.
Old 06-18-2004, 08:02 PM
barrydbrown barrydbrown is offline
Ford had a problem with the wiring harness on this model. If you did not get the wiring harness changed then you are having shorting problems with the wires. Basically, the insulation falls off while you are driving on all the wires under the hood.
Old 06-19-2004, 09:32 AM
it ended up being the alternator AND the wire to the battery . . . it was slipping through all of my amateur diagnostics by having two problems at once. in any event, it's all fixed . . . thanks for your help.
