ok i need help
ok i installed my new fuel pump, denso toyota supra pump, and its doing the same thing as before when i get to 130 kilomitters its getting a fuel cut i can hear it like its trying to suck in more fuel put it just cant do it like my tank is empty but its not possible because my tank is full, idk what else to do any one else have any advice ???
Maybe your injectors are to small for the ammount of fuel your pump is sending and also, maybe you don't have any pressure in your lines which would mean all your fuel is staying in the tank.
Re: ok i need help
how would i go and check that
Re: ok i need help
i have a 98 sr20det in my car
Re: ok i need help
Who put the 98 SR20DET in your car? Perhaps you should take it back to them and let them check...
If the injectors were the problem it would be at a certain RPM not speed.
that sounds like the pump is in wrong like its trying to get gas from the top of the tank instead of the bottom... Does it work fine with a full tank? maybe it has the wrong speed sensor and in instead of cutting fuel at 130mph...ish... its cutting at 70mph? also earlier and later Hump-top SRs have different ECUs i dunno if it would matter but yours could have gotten mixed up? |
Re: ok i need help
it dose the same thing on a full tank, speed senor idk ecu is fine
Re: ok i need help
have you tried a different ECU?
![]() HELL YEAH!!!!!! |
Re: ok i need help
damn you vRacing, now I cant stand up
Re: ok i need help
im thinking its a govenor problem any one know how to kill the sr speed govener
