Old 06-13-2004, 10:56 AM
kito311 kito311 is offline
Power Steering Problems
Hello there . . . I have a 97 cavalier LS and the power steering gave way yesterday while I was driving. I checked the steering fluid and it was real low. Filled it up to the top and by the time I got home all of the fluid was gone. I looked under the car and saw fluid dripping from either side of the car near each tire. Just curious if anyone has had a similar problem and if so what was done and how much did it cost. Thanks Alot!
Old 06-14-2004, 06:32 AM
pcv pcv is offline
First, you need to wash and dry the old leak area. Put fresh power steering fluid, and turning the steering full left and right a few times, do not lock it in one place for more than 10 secs, and observe the leak area now. You need to identify exactly where it is leaking from. 4 possibilities; 1, steering pump, 2. supply line, 3. return line and lastly the steering rack itself. The steering rack is the most expensive item.
Good Luck.
NOTHING LIKE AN OLD CAR.
