oil seals
could anybody tell me if it's possible to fit new valve stem oil seals whilst the head is in place on the 2.5 8v, with the cam removed and lifters out of the way. as you can on some of the ford engines (cvh). by putting number one piston to tdc then droping the valve onto the piston. Can this be done on 944, as it would be a lot less hassle. thanks
Re: oil seals
This doesn't help but couldn't you hold the valves in place w/ compressed air through the spark plug hole?
83 - Porsche 944 - daily driver 62 - VW Karmann Ghia - never ending restoration project 95 - Ford Mustang - wifes |
Re: oil seals
Yes you can do it. But use compressed air as 83-944 stated and have the cylinder on TDC as a safety. This is a common practice
Re: oil seals
would i not loose it through the rings? would air be enough?
Re: oil seals
You'll lose some air but if you leave the air line hooked up, it'll hold pressure.
Re: oil seals
So is there a tool for the springs whilst the head is in place?
Re: oil seals
a valve spring compressor should do.
any of the bottom 4 of these should do. i'd recommend the KD 3271 or 2078. You'll also find the air hold fittings there as well. http://www.mytoolstore.com/kd/kdengi13.html
