Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 06-13-2004, 07:48 AM
Ronaldo2004 Ronaldo2004 is offline
Angry Engine cutting out
I noticed at the end of a journey yesterday where there were no problems, that quite suddenly the engine cut out as I was taking off. I was able to get home by keeping the revs high but it kept it was behaving erratically as if there was a fuel problem. I started the car this morning and the same problem was there. It started but it kept cutting out. My neighbour who knows a bit about cars said it sounds like an oil filter problem.
Any help appreciated
Old 06-13-2004, 08:23 AM
Suprra_Girl's Avatar
Suprra_Girl Suprra_Girl is offline
Send a message via MSN to Suprra_Girl
hey is ur car air flow metered, try another one and see
have you popped a vacuum line off
if your car is afm check to see if there's any leaks after the airflow meter... get some engine start and spray some around the inlet manifold and vacuum lines etc, if you spray some and the revs pick up it has a leak that you'll have to remedy
oil blockages don't generally cause an engine to stall, the most they do is drop in oil pressure and you'll have a nice heavy paperweight to play with
well there's a couple of ideas to try anyway
hope it helps some
Look out Supa Supra from NZ is coming eventually
Stay tuned for episode 1, coming soon!
Testing a Star Wars Blaster Gun!
Old 06-15-2004, 04:00 AM
Re: Engine cutting out
hi there
my mistake but my neighbour said it was the fuel filter not the oil filter
thanks
Old 06-15-2004, 04:05 AM
haha yea should have figured it was the fuel filter not oil filter, hmmm yea that is a possibility as well
good luck with it
