Old 06-13-2004, 05:47 AM
mchengsp33 mchengsp33 is offline
Send a message via AIM to mchengsp33
carbon fiber decal
hi, i read the FAQ on c/f decals and i have some questions to ask...what method do i need to use if i try to apply the c/f decal to the whole car? not just the seat...is it ok if i just cut like a general shape of the area i want the decal on and stick the excess to the backside of the car body, since people are not going to see that anyway? also just another question, not about the c/f decal though..where can i get some 1/12 rims? thanks
Old 06-13-2004, 09:53 AM
freakray freakray is offline
AF Modelrater
Re: carbon fiber decal
You can use the method in the 'how to' to create a template for any part you want to cover, the technique remains the same, just the shape of the part changes.
What type of 1/12 rims?
AF User Guidelines
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
For the excess CF cut it, dont just try to hide it. You need to get some microsol too.
Have you checked freakrays CF tutorial? That may help you out, yes its for a seat, but you could get the idea of what to do to CF a whole body.
1/12 rims, RC rims.
-Mike
Old 06-14-2004, 10:05 PM
Re: Re: carbon fiber decal
hi, thanks for the replies guys, where can i find some 1/12 RC rims? I actually need them for customizing a plastic model, would the RC rims work? can i find the RC rims online? thanks
Old 06-14-2004, 10:27 PM
Macdaddy4738 Macdaddy4738 is offline
Send a message via AIM to Macdaddy4738
check www.towerhobbies.com
look for the micro RS4.
Old 06-14-2004, 10:30 PM
Vric's Avatar
Vric Vric is offline
for a full body, you will need a lot of microsol and a very good quality decal, don't buy cheap
Old 06-14-2004, 11:14 PM
thanks!! I will definitely spend money on some quality decals..can you guys suggest me some good ones? thanks
Old 06-14-2004, 11:18 PM
AF Modelrater
Have you checked out the tutorial yet?
I mention in the tutorial which C/F decals I have found to be the best ones.
AF User Guidelines
Old 06-14-2004, 11:25 PM
oh..sorry (what was i thinking??) yea thanks!!
Old 06-15-2004, 11:41 AM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
if I was gonna CF a whole car, I'd do it panel by panel. Just my 2 cents.
Old 06-15-2004, 11:51 AM
Vric's Avatar
btw if you have never worked with CF, it might be a bad idea to try to make a Full CF body !
Most of the modeller have big problem doing a CF hood without problem.
as for the brand, I used SAS one and Museum Collection. Even if both product are very good, Meseum Collection are a bit stronger, while SAS will react to Microsol easier
Old 06-15-2004, 01:22 PM
mike@af's Avatar
Micro RS4's are 1/24 scale.
-Mike
Old 06-17-2004, 02:17 AM
hi, i got another question about c/f decal..if i want to put other decals on the c/f decal (say...on the c/f hood)...do i put the decals directly on the c/f decal? or clearcoat the c/f decal first and then put the other decals on, and clearcoat everything after i am done? also can i use rubbing compound on c/f decals (with clearcoat) to make it shiny? thanks
Old 06-17-2004, 06:56 AM
AF Modelrater
Don't use rubbing compound on C/F decal, you'll ruin it, clear coat the C/F decal first.
It's probably safer to clear the C/F decal then apply the second lot of decals, but not necessary.
AF User Guidelines
Old 06-17-2004, 07:37 AM
geofroley geofroley is offline
Send a message via AIM to geofroley
No, their 1/18th. Your thinking of Mini Z's or XMODS. IF your looking for stylish rims, don't look on the R/C market. 1/12 R/C car rims look awful. TRy using 1/10th scale rims and see if that will work.
