Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-13-2004, 02:07 AM
aznbmxxxer aznbmxxxer is offline
Send a message via AIM to aznbmxxxer
6 speed integra
i have a turbo integra and 1st and 2nd gear doens't last very long. i want longer gears so i can stay in boost longer. is there anyway to make a integra 6 speed? maybe use a rsx type s tranny? and how much would it cost? or is it better just to regear the tranny.
Old 06-13-2004, 02:51 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: 6 speed integra
tranny's wouldn't bolt up... making it a 6 speed would reduce the length of gears... if you wanted long gears just get a tranny from an LS (b18b) bolt it up and call it a day
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 06-13-2004, 09:45 AM
YellowITR479 YellowITR479 is offline
Re: 6 speed integra
If you wanted to make your tranny a 6 speed than expect to drop between 10K - 20K. Just drop the LS like Delerious said....I did
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 06-13-2004, 02:44 PM
boosted331 boosted331 is offline
Re: 6 speed integra
If you have a GSR motor in your car already, don't belive the hype. Your car will be faster with the GSR trans than the LS trans.
Old 06-13-2004, 02:50 PM
DeleriousZ's Avatar
Re: 6 speed integra
yeah for sure the gsr trans will be faster, but he said he wanted longer gearing.. so we gave him what he asked for
Old 06-13-2004, 03:04 PM
how come the gsr tranny will be faster if its shorter? wouldn't you be switching gears faster and not be in boost as long?
Old 06-13-2004, 05:09 PM
Re: 6 speed integra
This topic could go back and fourth forever. I sounds like having a GSR Tranny WOULD make your car faster cause you are going through the gears faster.
If you are looking for a street machine I would go w/ the LS trans because of the longer gears, It really helps 1st gear traction as long as you have a LSD. Without one you are just pissing in the wind
Old 06-13-2004, 05:35 PM
DeleriousZ's Avatar
Re: 6 speed integra
speaking of lsd's.. where'd u pick up your quaife lsd from? the manufacture'er's (lol) site or somewhere else?
Old 06-13-2004, 05:49 PM
B1SiR6A's Avatar
B1SiR6A B1SiR6A is offline
Re: Re: 6 speed integra
Originally Posted by Delerious93integra
manufacture'er's
Classic
"Check that young man for nitrous"
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Currently 4th in BHRA All Motor Class...Soon to be 2nd (I hope)
...Theres gonna be alotta slow singin, an flower bringin if I hear my car alarm start ringin ...
Old 06-13-2004, 06:57 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Old 06-13-2004, 08:34 PM
i had to look at that one twice then I seen it...that was funny
I got the quaife when I bought the tranny, guy never put it in.
www.morepowerracing.com has quaife's for sale
Old 06-13-2004, 08:59 PM
Re: 6 speed integra
Think about it for just a second. Shorter gearing makes you accelerate quicker in a naturally aspirated car, right? So immediately longer gearing means you accelerate faster with a turbo because you "stay in boost longer"? Don't belive everything you hear on these forums.
