Old 06-12-2004, 10:20 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
rear end services required (again)
suit up boys cause i need you again. so i swapped out my rear-axle two weekends ago, thing worked magically for a couple weeks untili tonight. i was drivin around and suddenly i started to get a creaking/clunking sound. now, it only makes the noise in reverse and when i make a turn in reverse (i.e. if im goin in a strait line it dont do it). also, it only does it when its in gear (i.e. if im in neutral it dont do it). i couldnt really determine where the noise was coming from too well inside the car but it sounded like it was in the center, probably from the rear half of the car. im thinkin maybe bum differential but i dont know bout these things. any takers on this one?
ps- sorry bout the long post...
Old 06-12-2004, 10:36 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: rear end services required (again)
is your torque arm tight??
Old 06-12-2004, 10:38 PM
camarochick's Avatar
camarochick camarochick is offline
Send a message via AIM to camarochick
Question Re: rear end services required (again)
No don't have any suggestions but what a bummer!
Old 06-13-2004, 01:30 PM
just got a look at my axle. first thing i noticed when i got under the car is that ive got a wet leak coming from around the pinion. there's a good bit of oil all over my torque arm and exhaust. im guessing my pinion seal is bad. now my question is could this be responsible for the problem ive described above...
Old 06-13-2004, 02:20 PM
umm i dunno.... it could, maybe the pinion is jumping when you put it in gear, but it should do it when you put it in D also.. hmmmmmmm maybe its something other then the rear axle making the noise....
Old 06-13-2004, 02:57 PM
it almost sounds like one of the brake calipers is stuck engaged and the wheel is popping as it rolls, but i dont think that is a plausible cause considering that my emergency brake is not hooked up right now (thats a different and non related problem). i dont know could there be something wrong with the u-joints? also i was reading some old posts that said a similar noise was made but not under the same conditions and those were transmission mounts...
Old 06-13-2004, 02:58 PM
yea it could very well be your u joints
Old 06-13-2004, 02:59 PM
and my car use to do the same thing, the rubber thing on the trans mount or the torque arm thing ripped and sometimes it would smack when i put it into gear....
Old 06-14-2004, 09:57 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
is it a clutch pack posi?
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 06-14-2004, 11:59 AM
no its out of a 97 RS so its an auburn, but it is limited slip...
Old 06-14-2004, 12:00 PM
i just realized how redundant that last post is...
Old 06-14-2004, 06:50 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
well i would say that its not brakes, otherwise it would be doing it all the time, forward, backward, strait, in a turn, if it was just a pinion seal, same deal, whenever the driveshaft turned the pinion, it would do it. seeing as it only does it in turns, i would say its the differential carrier, something internal let go, probly the clutch packs, but could be something else. but id say thats where the problem is.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 06-14-2004, 07:12 PM
thats what i was thinking, just hoping i didnt have to scrap the new rear-end...
Old 06-14-2004, 07:22 PM
89IROC&RS's Avatar
eh dont fret, might be something simple, just a bad set of clutches, or a loose bolt or something along those lines. i think if the whole rear end grenaded youd know it by now.
Old 06-14-2004, 09:04 PM
well my point is that i have a 30 day warranty on the end so i can either try to fix this one and run with it, or just get my money back and try to find another one. it's a tough decision when 500 bucks is on the line...
