Old 06-12-2004, 10:10 PM
mystizo916 mystizo916 is offline
low idle, reset computer? - newbie
i have a 95 gsx awd automatic. one day i ran the gas tank dry and the car has been idling at 200 rpm when its in gear ever since. 900 rpm in park or neutral. i read an article on a supra stating that when you run the tank dry, the computer switches to a "conservative" mode, effectively losing you horsepower. they said it was corrected by simply reseting the computer. i was wondering if this might be the same case for the eclipse. if so, how do i reset my computer? if not, what else could i do to correct the problem? the plugs have been changed(and gapped correctly) and i've ran injector cleaner a few times since. any help would be greatly appreciated. thanx!
Old 06-12-2004, 10:14 PM
96gsn 96gsn is offline
Send a message via Yahoo to 96gsn
Re: low idle, reset computer? - newbie
disconnect the ground wire for a few minutes
Old 06-12-2004, 11:42 PM
k3rnel k3rnel is offline
Send a message via AIM to k3rnel
pretty easy solution, you might want to check your ECU for a reset button or a power wire to disconnect if the above doesnt work.
[ mod it | race it | love it ]
Old 06-13-2004, 07:23 PM
has anyone experienced a problem like this before?
Old 06-13-2004, 10:21 PM
RSLaser RSLaser is offline
besides reseting the computer, check your speed cable on the throttle body.
Old 06-13-2004, 10:50 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Never heard of it. Like said above, disconnecting the ground wire on your battery for a few minutes (maybe 15-30 to be safe) will reset the ECU. If you do that and still have problems after, it's not the ECU.
Old 06-14-2004, 06:54 PM
havicks29's Avatar
havicks29 havicks29 is offline
Send a message via Yahoo to havicks29
Re: Re: low idle, reset computer? - newbie
Im actually having the same problem with my 99 GS auto... looking for the same answer
-99 eclipse gs
-420a motor
-auto trans
-arospeed exhaust
-cold air intake
-GSX spoiler
Old 06-15-2004, 05:51 PM
havicks29's Avatar
Re: Re: Re: low idle, reset computer? - newbie
ok i tried it out. and it actually worked! so give it a try.
-99 eclipse gs
-420a motor
-auto trans
-arospeed exhaust
-cold air intake
-GSX spoiler
Old 06-15-2004, 07:22 PM
joemathews's Avatar
joemathews joemathews is offline
Make sure your AC isn't on. I drop to 500 or so rpm at idle if mine is on
1996 Eagle Talon
Old 06-17-2004, 09:25 PM
help!!!! i reset the computer and now it idles at around 100-150 rpm when its in drive and about 600 rpm in park or neutral.
