Old 06-12-2004, 09:10 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
help
ok i am about put my block back together and was wondering what all i need new as in gaskets and seals for stock d16a6....onlky thing i know is a exhaust and intake gasket,head gasket,oil pan gasket and screen
Old 06-12-2004, 09:48 PM
91civicDXdude's Avatar
Re: help
I would replace the front and rear main seals. You also have the thermostat housing gasket, the front waterneck gasket, and the valve cover gasket. You may or may not have removed some of those things, but i would definately replace the main seals while the engine is apart.
Old 06-12-2004, 11:34 PM
Re: help
right on man, i just got told that from a friend block is getting hot tanked so i mine as well replase every gasket ....thanks
Old 06-16-2004, 05:46 PM
Re: help
in this service book for the block says replace o-rings or something when i dismantle block...my block is geting honed and hot tank at the moment if anyone can tell me what these o rings there talk aobut please fill me in for the time being i went bought all new gaskets
Old 06-16-2004, 09:15 PM
Re: help
the only o rings that i know of is the seal for the oil control jet & distributor. Its recommended that you change both of these on an engine rebuild as well..
Old 06-16-2004, 09:43 PM
crx91's Avatar
crx91 crx91 is offline
Re: help
piston rings.same as o rings just dif name.they should replace them since their goin to hone out the cylinder walls.
Old 06-16-2004, 10:18 PM
Re: help
thanks dude....crx thanks for info but i already have replace them i was talking about o rings not piston rings....buti guess i get those 2 o irngs that way i am on the safe side
