Old 06-12-2004, 04:28 PM
SMoOtHSTuNNA SMoOtHSTuNNA is offline
Runnin Wrong
hey guys..got a gsr hatch .it's runnin real rich and isn't pullin the same. it seems like my air 2 fuel ratio is messed up...i a vtec controller but never messed with it...i can feel it...its not pullin as hard as it used to and isn't as loud...jus wonderin if anyone had the same problem and/or if anyone can suggest anything.
Old 06-13-2004, 01:33 AM
YellowITR479 YellowITR479 is offline
Re: Runnin Wrong
is your vtec working?
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 06-14-2004, 05:51 PM
Re: Runnin Wrong
yeah..its working...
Old 06-14-2004, 06:15 PM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
Re: Runnin Wrong
if it was running properly before what did you change to have it run like it does now?
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 06-15-2004, 03:58 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
do a compression check
Team Lonely Drivers
