Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 06-12-2004, 09:57 AM
Weezersim Weezersim is offline
help
Im trying to replace my starter and the solenoid absoletely will not budge. I took off the two bolts that hold the starter in place and I cant find any other bolts, nuts, ect. to remove, so it should just slide off of those pins, but it wont! Is there something I'm missing?
Old 06-12-2004, 12:42 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: help
Not as long as you have disconnected the electical connections. Try giving it a whack on the side with a plastic hammer or equivalent. If that doesn't work, insert the lower bolt 3/4 of the way in and use a prybar to push inward against the bolt (in the direction to push the starter out).
