Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 06-12-2004, 05:43 AM
HondaSi88 HondaSi88 is offline
93 villager just died need some ideas
My wife just got home and tells me that the van died when she parked it tonight. I got outside and try to start it up but it only cranks.....everything electrical works and all the belts are tight oh and i checked all the fuses and added some gas but nothing.
So what is the next step? I know this sounds general but i am in the troubleshooting mode so im trying everything thanks!
Old 06-13-2004, 11:02 AM
NocturN's Avatar
NocturN NocturN is offline
Send a message via AIM to NocturN
hmm
check spark plugs, also fuses
theres some fuses in black plastic containers under the hood.
in case you don't have one, go to your local parts dealer and get a book on the 93 villager. no brand names mentioned, this is not an ad. Theres stuff i didn't know about the villager ex: you have to open two bleeder screwes while filling the radiator with coolant and close them after water comes out. Filling the cooling system in a conventional way may allow air bubbles to form in the system and you might over heat.
Old 06-28-2004, 09:49 PM
eltigre eltigre is offline
Re: 93 villager just died need some ideas
When was the last time you did a timing belt change? Take the distributor cap off and crank it and see if the rotor turns, if it doesn't then you broke your timing belt....
