Old 06-12-2004, 03:46 AM
mchengsp33 mchengsp33 is offline
Send a message via AIM to mchengsp33
primer question
hi just wondering what a metalic primer is used for, and how is it used? thanks. Also how to get the model engine look shiny and polished (for example, how do people get the tubes to be shiny)? is that where the metalic primer comes in? thanks
Old 06-12-2004, 04:57 AM
shieldwulf's Avatar
shieldwulf shieldwulf is offline
Re: primer question
A metal primer helps to "hold" the paint onto the metal surface.
As an experiment, try putting on some paint onto a metal part, e.g. a key. Once dried, u will be able to easily scrape it off with your finger nail.
Then this time round, apply metal primer (I use Gunze's transparent metal primer) onto the metal part and let it dry. Follow on with the actual paint and let dry. Now try to scrape off the paint with your finger nail....it is much more difficult to get it off this time.
I gained experience from this experiment when I was colour coding my keys using Gundam markers. Then I realised the paint don't hold on for long before I have to re-apply again (due to bunch of keys scratching each other). Later I bought a bottle of Gunze metal primer and did the second part of my experiment. Now the colours stay!
Old 06-12-2004, 09:37 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: primer question
As far as engine components being shiny, sometimes they are replaced by aluminum tubing, othertimes they are painted with alclad.
-Mike
Old 06-13-2004, 01:34 AM
Re: Re: primer question
thanks for the reply people! just one more question...so the metal primer is only good for metal parts (i.e transkit, photo-etched parts) right? if i only have plastic parts, the best i should use is the original primers (like the tamiya surface primers)? thanks
Old 06-13-2004, 09:54 AM
mike@af's Avatar
Re: primer question
I use Tamiya Surface primers all around.
Oh, the transkits are usually resin.
-Mike
Old 06-13-2004, 09:56 AM
freakray freakray is offline
AF Modelrater
Re: primer question
Yes on the primer, the metal primer is for metal parts, plastic parts primer like Tamiya makes is good on plastic parts.
AF User Guidelines
Old 06-18-2004, 12:27 AM
hi, i just bought the fine surface primer (white) and surface primer (gray) from tamiya, just in case i want to paint different colors. Can anyone tell me what's the difference between fine surface primer and surface primer? Which color of primer should i use for which paint colors, and also what's the "L" stands for on where it says surface primer? thanks
Old 06-18-2004, 08:35 AM
tonioseven's Avatar
Re: primer question
The "L" stands for "Large" as in the size of the can since it comes in 2 sizes. The white usually dries a bit smoother and is used to prime cars that will have lighter colors such as yellow, red, white, and etcetera.
Old 06-18-2004, 08:47 AM
ywwong ywwong is offline
Re: primer question
I start using Gunze primer... and it seems smoother than Tamiya's
Old 06-18-2004, 09:44 AM
iceblend's Avatar
iceblend iceblend is offline
Re: primer question
What about this 'mr base white' from gunze? does it work like a primer?
Work In Progress
Old 06-21-2004, 03:13 PM
hi, thanks, if i want to paint the car in silver (or some color in that range), what color of primer should i use? thanks
Old 06-21-2004, 03:16 PM
Afrofent Afrofent is offline
Send a message via AIM to Afrofent Send a message via Yahoo to Afrofent
Same here.
-AFROFENT-
"Dream as if you'll live forever, but live as if you'll die today."-James Dean
"Halo 2 is a lot like Halo 1, only it's Halo 1 on fire, going 130 miles per hour through a hospital zone, being chased by helicopters and ninjas... And the ninjas are all on fire, too" ~ Jason Jones, Bungie
"That harry potter girl you guys are talking about looks sorta like a skinny pig"-Wade
Old 06-21-2004, 03:53 PM
Macdaddy4738 Macdaddy4738 is offline
Send a message via AIM to Macdaddy4738
Re: Re: Re: primer question
it depends on how you want it to look. If you want a "brighter" silver color then use white. If youd like a slightly "darker" silver then try gray. If you understand what i mean...its kinda hard to explain.
Old 06-21-2004, 04:35 PM
shieldwulf's Avatar
If you plan to use Tamiya primers, I would recommend only the "fine" surface primer for car model kits. The other "normal" surface primer is quite coarse and you would have to spend more time sanding it smooth, and which means making sure every nook and cranny of the car body which you've sprayed using the "normal" surface primer is carefully sanded to smooth. And in my humble experience it is quite exhaustive and unnecessary. So go for only the "fine" surface primer if you are building cars. I'm not sure whether the "fine" surface primer is available in both white and gray colours.
But in the next round, you may want to try Gunze's "Mr Surfacer" which are also primers. They are available in different grits. Go for the Mr Surfacer 1000 or Mr Surfacer 1200 primers which are so smooth you almost don't feel the need to sand after primering. Gunze's primers are far more superior in terms its ease of not requiring too much sanding work, and the pigments are finer. This is of course of my own opinion. I'm sure everyone has their own fav primer, and considering the "geographic availability"...you know.
And for the record, Gunze's 1000 and 1200 primers are definitely smoother than Tamiya's. Because I had tried both. Been there, done that.
Old 06-21-2004, 05:24 PM
GvEman's Avatar
GvEman GvEman is offline
Re: primer question
Hello i have the gray tamiya surface primer. and i was thinking if i need to sand it before i starts laying the coats of the paint... and do i need to waint a hole week for the primer to dry before painting?
Best Regards
Anton
