Old 06-12-2004, 01:01 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Stock fuel pump pushing 90 Psi
I tested my fuel pump today to see how high I could get the pressure. I have a adjustable pressure reg. and B&M gauge. It went all the way up to 90 psi. Is this normal? Or is this one a aftermarket pump?
I did this test cause Im going turbo, and no it did not run real good at that high of a PSI. But if it can go that high Im not going to need a aftermarket.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 06-12-2004, 01:35 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
as you go higher and higher above normal pressure, you actually start to lose fuel. i mean the fuel pressure goes that high but the amount of fuel at that pressure is alot less so your car will start to run lean
Team Lonely Drivers
Old 06-12-2004, 01:55 AM
Cjz89civic's Avatar
AF Premium User
Re: Stock fuel pump pushing 90 Psi
got ya ok but that goes for a aftermarket fuel pump too then. Right?
