Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 06-11-2004, 10:17 PM
timinstl timinstl is offline
Send a message via Yahoo to timinstl
Honda CRX Question
Im new to the import seen and was wondering if it is possible to put a 2001 Honda Vtech engine in an 87 crx? Id so, anything I should know or anything I should get before I get started. Any help would be appreciated.
Old 06-11-2004, 10:57 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: Honda CRX Question
Hasport sells a kit that will allow you to install any B-series motor into an '84-'87 Civic/CRX. Most people prefer to install a D16A1 from an '86-'89 Acura Integra. The D16A1 is a 1.6 liter motor and is a direct bolt in for a first gen CRX. The american version of the D16 produces 113HP and the Japanese ZC version produces 137HP. A stock '87 CRX SI produces 97hp, and in a car that weighs about 2000 lbs, 40HP is a huge difference. You can also add on a cold air intake and header/exhaust system to get even more power out of the D16. Forget about an H22 motor, unless you are building a drag car. It's just too much weight for this little car and it will handle extremely poorly!
Check out these links:
http://www.hasport.com/
http://www.redpepperracing.com
http://www.automotiveforums.com/vbul...d.php?t=199192
