Old 06-11-2004, 08:54 PM
jetblack929 jetblack929 is offline
Question need help jdm swap
ok so i have a 98 civic and i want to swap a jdm b18c-rg2 i can get the tranny axles shift linkage ecu and all the parts to run, but i was wondering since the steering column is on the right side if the gears would be different instead of
1 3 5
2 4 R
would it be
5 3 1
R 4 2
and would the shifter fit in an american model civic?
any help would be greatly appreciated.
one more thing, would it be easier to go with an usdm b18c-r
Old 06-13-2004, 02:48 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: need help jdm swap
it will be the same as the American way
1 3 5
2 4 R
It should be the same difficulty of swapping in a UDM as a JDM engine.
Old 06-13-2004, 05:25 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
yes it is the same, even on rhd cars first is still top left and fifth is top right... it'd be weird driving a rhd car and still shifting the same way... it'd take a while to get used to i'm sure
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 06-14-2004, 08:22 AM
thanks guys or girls dont know
