Old 06-11-2004, 06:44 PM
Dumpy2's Avatar
Dumpy2 Dumpy2 is offline
Send a message via MSN to Dumpy2
my civic won't start
i bought this civic a couple of weeks ago for $150, it ran fine, the engine would just kind of stumble when accelerating at low rpms, then today i drove it to work it got there fine, but then when i went to start it up the engine wouldn't turn over, i thought maybe it was the fuel filter so i put a new one in, but nothing, i have new plugs that i can put in, u guys think that would fix it or is it like the fuel pump or something else? any info would be great, thanks
Old 06-11-2004, 09:12 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: my civic won't start
Well, let's make sure we all mean the same thing. When you say it won't turn over do you mean nothing happens? Please clarify.
Old 06-11-2004, 09:39 PM
Dumpy2's Avatar
no no, the engine just won't start up, it has power and all that
Old 06-11-2004, 10:05 PM
johnb16a2's Avatar
OK, do you hear the pump cycle on and off when you turn the key to the Run position?
Old 06-11-2004, 10:30 PM
Dumpy2's Avatar
i was by myself... so i couldn't tell
Old 06-12-2004, 10:24 PM
johnb16a2's Avatar
You could look in the filter for gas or you could try starting it a few times and snif the tail pipe for gas fumes.
If the pump is working try testing the igniter (Autozone can help here), the main relay, and look for codes on the ecu.
Old 06-13-2004, 02:39 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
when you turn the key on, you should hear the fuel pump prime for a couple seconds then stop
you say it has power, but does the engine crank at all ? do you ahve spark ? any codes ?
Team Lonely Drivers
