Old 06-11-2004, 04:46 PM
rphill1 rphill1 is offline
A/C Compessor Keeps Cycling
I have a 95 Tahoe 2-dr, 4x4, 150K miles. During idle, the A/C compressor cycles in and out about one-two times per second. During highway use it operates fine, and the cooling is excellent. Can anyone tell what part need replacing?
Old 06-11-2004, 09:46 PM
mjgjr72 mjgjr72 is offline
Re: A/C Compessor Keeps Cycling
may be low on freon
Old 01-14-2005, 08:26 AM
tenth_rc_Racer tenth_rc_Racer is offline
Send a message via AIM to tenth_rc_Racer Send a message via Yahoo to tenth_rc_Racer
I have a 98 tahoe 4dr 2wd, and have the same problem. I know its not low on refrigerant......... any ideas or suggestions????
Old 01-14-2005, 08:38 AM
Re: Re: A/C Compessor Keeps Cycling
It only does it occasionally while idling, even in cool weather. I've been meaning to replace the pressure switch just to see if that cure the problem. It's about a $15 part that can be installed in 30 seconds. If I ever get around to doing it, I'll let you know if it works.
Old 01-14-2005, 08:39 AM
cordovaass's Avatar
cordovaass cordovaass is offline
Send a message via AIM to cordovaass
its supposed to do that. some other makes do the same thing.... it automaticly keeps a set pressure even if you are not running your a/c
i had to same problem i asked a guy at my work who has been fixing cars for over 30years and he said its normal.
Old 01-14-2005, 08:42 AM
Sure, the compressor's supposed to cycle, but at the rate of about 3 times per second.
Old 01-14-2005, 11:11 PM
cordovaass's Avatar
three times a second? is that possible...? ill check mine and get back to you. i think mine cycles about every 10 seconds.
Old 01-17-2005, 11:41 PM
i8uiky i8uiky is offline
once evry 10 sec is fine 3 times a sec you need to check your pressures to find out if your freon is low
and the ac will run when defrost is on for 2 reasons
to pull moisture out of the cab so the window wont fog up and to keep the seals lubrecated
