Old 06-11-2004, 03:46 PM
jaedreamah jaedreamah is offline
ground noise?? how to fix?
hey....just a question...i believe i have some ground noise from poor wiring. everytime i step on the gas...and the system is on pretty low...i hear some noise that increases as i step on the gas more.
am i correct that that is ground noise that i'm getting? and if so...can someone give me some advice how to fix this problem.
if i'm wrong...can someone correct me and help me out?
thanx
Old 06-11-2004, 04:01 PM
Re: ground noise?? how to fix?
alright guys...i've searched a bit in this forum..and found some pretty good discusions about ground noise, but if anyone still want to give any further advice, i'd appreciate it.
thanx
Old 06-11-2004, 05:20 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
alternator whine is usually caused by running your RCA cables next to a noisy device
Old 06-11-2004, 10:29 PM
i hear the noise coming from the subs though...when i step on the gas, it gets louder...but i can only hear it when the volume is pretty low...but when the volume is loud i can't hear it.
Old 06-12-2004, 09:36 AM
Icantgetno Icantgetno is offline
PaulD is right, but it can also be caused by a faulty ground. make sure you have a good groud and isolated RCAs and you should be gtg if not you prolly have a cheep component int he mix.
Old 06-12-2004, 10:50 PM
Audio Guy
yes, cheap components occasionally suffer from poor ground isolation .... it allows noise on the power/ gnd wires to get into the audio path.
Old 06-13-2004, 01:33 AM
Fewman Fewman is offline
Send a message via AIM to Fewman
Just a side note, I had the same problem, I re-did all my wiring to as perfect as I could get it, seperated RCA, tried putting an on/off switch on the power, and everything else in the book. When it came down to it, nothing actually worked. My only succesfull "fix" was to turn the trebble gain way down, and match the bass to it (all on the AMP, not the head unit). After I adjusted the head unit, it sounds almost the same but without the annoying alternator noise. Wish those other tips helped, though.
Old 06-19-2004, 09:51 AM
Cman333 Cman333 is offline
many different causes
poor quality RCA's
RCA's run beside powerwire
Not grounded in a good place
alternator and/or battery may need better ground
ground wire too long (wanna keep under 12")
http://www.boyzaudio.com
Old 06-19-2004, 04:25 PM
Audio Guy
Re: Re: ground noise?? how to fix?
poor quality RCA's (PROBABLY THE CULPRIT)
RCA's run beside powerwire (NO, BUT RCA'S PROBABLY RUNNING NEXT TO A NOISY PIECE OF EQUIPMENT)
Not grounded in a good place (ONLY IF YOU HAVE EQUIPMENT THAT HAS POOR ISOLATION BETWEEN SIGNAL GROUND AND POWER GROUND)
alternator and/or battery may need better ground (SEE ABOVE)
ground wire too long (wanna keep under 12") (GOOD IDEA TO KEEP IT SHORT, BUT NOT FOR NOISE SUPPRESSION)
The truth is, EVERY car has this noise .... just that better stereos suppress it, or it is so low it's not audible. It's almost alwaysose to a noise source or equipment with poor isolation.
