Old 06-11-2004, 02:01 PM
GTPgirl's Avatar
GTPgirl GTPgirl is offline
Send a message via ICQ to GTPgirl Send a message via AIM to GTPgirl Send a message via Yahoo to GTPgirl
SES Light and loss of acceleration
Okay...I posted a while back about my SES light...it only comes on when the car has been driven a really long way. After 3 key cycles, it goes back off. I was told that could be a bad o2 sensor, since the car is not acting up.
Also, I seem to have lost some acceleration power, and the car kinda feels like it's bogging down or something. I'm also hearing a sort of whining noise on the driver's side. I'm thinking my fuel filter may need to be replaced.
Any other ideas?
GTPgirl
Black 1998 Camaro - currently driving
Black 1999 Grand Prix GTP - burned March 2008
Plum Crazy 1970 Dodge Challenger - work in progress!
Old 06-11-2004, 03:25 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: SES Light and loss of acceleration
Get the car scanned. See what code is being thrown
Old 06-12-2004, 01:35 PM
The ORIG. Dig. Oxy's Avatar
The ORIG. Dig. Oxy The ORIG. Dig. Oxy is offline
SES light the same as a "check Engine light"?
Old 06-12-2004, 01:36 PM
Ripn12s's Avatar
SES = Service Engine Soon
so ya
Old 06-12-2004, 01:39 PM
The beauty of newer cars... Codes make it easier to troubleshoot.
Old 06-12-2004, 07:09 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
GTP Girl do me a favor go to the person who told you your SES light is an O2 senosr and slap them hard because they are talking out of there ass. The reason he is talking out his ass is because the computers can have tones of codes stored and some of them you won't notice anything wrong.
Here is a list of DTC that can be stored in your PCM.
DTC P0101 Mass Air Flow (MAF) Sensor Performance
DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
DTC P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
DTC P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
DTC P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
DTC P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage
DTC P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
DTC P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
DTC P0121 Throttle Position (TP) Sensor Performance
DTC P0122 Throttle Position (TP) Sensor Circuit Low Voltage
DTC P0123 Throttle Position (TP) Sensor Circuit High Voltage
DTC P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
DTC P0131 HO2S Circuit Low Voltage Sensor 1
DTC P0132 HO2S Circuit High Voltage Sensor 1
DTC P0133 HO2S Slow Response Sensor 1
DTC P0134 HO2S Circuit Insufficient Activity Sensor 1
DTC P0135 HO2S Heater Performance Sensor 1
DTC P0137 HO2S Circuit Low Voltage Sensor 2
DTC P0138 HO2S Circuit High Voltage Sensor 2
DTC P0140 HO2S Circuit Insufficient Activity Sensor 2
DTC P0141 HO2S Heater Performance Sensor 2
DTC P0171 Fuel Trim System Lean
DTC P0172 Fuel Trim System Rich
DTC P0201 Injector 1 Control Circuit
DTC P0202 Injector 2 Control Circuit
DTC P0203 Injector 3 Control Circuit
DTC P0204 Injector 4 Control Circuit
DTC P0205 Injector 5 Control Circuit
DTC P0206 Injector 6 Control Circuit
DTC P0230 Fuel Pump Relay Control Circuit
DTC P0243 Supercharger Boost Solenoid Control Circuit
DTC P0300 Engine Misfire Detected
DTC P0325 Knock Sensor (KS) Circuit
DTC P0327 Knock Sensor (KS) Circuit Bank 1
DTC P0332 Knock Sensor (KS) Circuit Bank 2
DTC P0336 Crankshaft Position (CKP) Sensor Circuit
DTC P0341 Camshaft Position (CMP) Sensor Performance
DTC P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient
DTC P0403 Exhaust Gas Recirculation (EGR) Solenoid Control Circuit
DTC P0404 Exhaust Gas Recirculation (EGR) Open Position Performance
DTC P0405 Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
DTC P0420 Catalyst System Low Efficiency
DTC P0440 Evaporative Emission (EVAP) System
DTC P0442 Evaporative Emission (EVAP) System Small Leak Detected
DTC P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit
DTC P0446 Evaporative Emission (EVAP) Vent System Performance
DTC P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
DTC P0452 Fuel Tank Pressure Sensor Circuit Low Voltage
DTC P0453 Fuel Tank Pressure Sensor Circuit High Voltage
DTC P0462 Fuel Level Sensor Circuit Low Voltage
DTC P0463 Fuel Level Sensor Circuit High Voltage
DTC P0480 Cooling Fan Relay 1 Control Circuit
DTC P0481Cooling Fan Relay 2 Control Circuit
DTC P0506 Idle Speed Low
DTC P0507 Idle Speed High
DTC P0530 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit
DTC P0560 System Voltage
DTC P0601 Control Module Read Only Memory (ROM)
DTC P0602 Control Module Not Programmed
DTC P0620 Generator Performance
DTC P0650 Malfunction Indicator Lamp (MIL) Control Circuit
DTC P0656 Fuel Level Output Circuit
DTC P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
DTC P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
DTC P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
DTC P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
DTC P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
DTC P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
DTC P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
DTC P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
DTC P1133 HO2S Insufficient Switching Sensor 1
DTC P1134 HO2S Transition Time Ratio Sensor 1
DTC P1260 Fuel Pump Speed Relay Control Circuit
DTC P1336 Crankshaft Position (CKP) System Variation Not Learned
DTC P1351 Ignition Coil Control Circuit High Voltage
DTC P1352 Ignition Bypass Circuit High Voltage
DTC P1361 Ignition Control (IC) Circuit Low Voltage
DTC P1362 Ignition Bypass Circuit Low Voltage
DTC P1374 Crankshaft Position (CKP) High to Low Resolution Frequency Correlation
DTC P1380 Misfire Detected - Rough Road Data Not Available
DTC P1381 Misfire Detected - No Communication with Brake Control Module
DTC P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance
DTC P1441 Evaporative Emission (EVAP) System Flow During Non-Purge
DTC P1546 Air Conditioning (A/C) Clutch Relay Control Circuit
DTC P1554 Cruise Control Feedback Circuit
DTC P1571 Traction Control Torque Request Circuit
DTC P1573 Lost Communications with Brake/Traction Control (EBTCM) System
DTC P1585 Cruise Control Inhibit Output Circuit
DTC P1626 Theft Deterrent Fuel Enable Signal Lost
DTC P1629 Theft Deterrent Fuel Enable Signal Not Received
DTC P1635 5 Volt Reference Circuit
DTC P1637 Charging System Lamp Control Circuit
DTC P1639 5 Volt Reference 2 Circuit
DTC P1653 Low Engine Oil Level Lamp Control Circuit
DTC P1673 Engine Coolant Temperature Lamp Control Circuit
DTC P1689 Traction Control Delivered Torque Output Circuit
DTC P0218 Transmission Fluid Overtemperature
DTC P0502 Vehicle Speed Sensor (VSS) Circuit Low Input
DTC P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent
DTC P0711 TFT Sensor Circuit Range/Performance
DTC P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Input
DTC P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Input
DTC P0716 Input Speed Sensor Circuit Intermittent
DTC P0717 Input Speed Sensor Circuit Low Input
DTC P0719 Brake Switch Circuit Low Input
DTC P0724 Brake Switch Circuit High Input
DTC P0730 Incorrect Gear Ratio
DTC P0741 TCC System Stuck Off
DTC P0742 TCC System Stuck On
DTC P0748 Pressure Control Solenoid Circuit Electrical
DTC P0751 1-2 Shift Solenoid Valve Performance
DTC P0753 1-2 Shift Solenoid Circuit Electrical
DTC P0756 2-3 Shift Solenoid Valve Performance
DTC P0758 2-3 Shift Solenoid Circuit Electrical
DTC P1810 TFP Valve Position Switch Circuit
DTC P1811 Maximum Adapt and Long Shift
DTC P1814 Torque Converter Overstressed
DTC P1860 TCC PWM Solenoid Circuit Electrical
DTC P1887 TCC Release Switch Circuit
So not you can see that it's impossible to tell what the problem is what out a scanner reading the codes.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 06-13-2004, 09:51 PM
GTPCatz GTPCatz is offline
Banned
and thats not even the full list!
You still have Body Codes and Transmission Codes!
Old 06-14-2004, 10:32 AM
rubberman rubberman is offline
i would go to your local Autozone store. they will scan the car for free plus look up the code to find out what it means.
2000 Grand Prix GT w/ gold package.
K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe
2004 Chevy Trailblazer EXT
Keep on Keeping on...
Old 06-15-2004, 06:10 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Go get it scanned. When a ses is on is easierto troubleshoot
