Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 06-11-2004, 01:46 PM
cyber641's Avatar
cyber641 cyber641 is offline
Send a message via AIM to cyber641
93 olds 88 Ignition problems
I have a 1993 olds 88 royal with the standard 3.8 liter and im having some ignition problems
- I bought it from a older lady, in which was sitting under a tree for two years
- When i got it, it didnt run ( bad ignition modual ) in which i bought a a ignition modual / coils from the local junkyard
- Well it was still running rough however, my computer wasnt stating anything is wrong with it ( slow acceleration, rough ignition around 55 mph and poor fuel ecnomy 12- 14 mpg)
- that modual was short lived in which i bought a new one and installed
- still running rough
- bought a new 02 sensor slightly better not and dramatic increase however
- I blew a fitting and lost my coolant and overheated, since then ive been running off 4 cylinders (the lower coil isnt firing)
- nor is my computer stating anything
any ideas on what the problem is? thanks
Cyber641
Old 06-12-2004, 01:42 PM
auto trainy auto trainy is offline
Re: 93 olds 88 Ignition problems
Did you replace the wires?and if your coil isnt being signaled it also won't fire.Try cleaning the bottom of the ignition module and put a little never sneeze on it.
Old 06-12-2004, 01:46 PM
sorry to re-reply but does your engine light ever come on like when you first turn on your ignition key?
Old 06-12-2004, 07:07 PM
rben rben is offline
Send a message via AIM to rben Send a message via Yahoo to rben
Could it be your computer. Have you unplugged the injectors one at a time to see if there is a change.
Old 06-15-2004, 12:49 PM
cyber641's Avatar
cool thanks everyone
- the wires were indeed bad
- which in turn burnt out the ignition modual
But the problem is solved thanks i didnt even think of faulty wires thanks again and sorry for such a long delay.
Cyber641
