Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 06-11-2004, 12:07 PM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
Surges at Idle....
This post is for a friend in Canada.......
1999 Trooper V-6 FI .........New Fuel Pump, filter, tuneup..etc....
The vehicle surges 1K-2K rpm) on start up for 3 or 4 time then quits....but not all the time.
Otherwise drives fine....Does it hot or cold.
No codes or errors....no backfire, missing, stumbling...
Any ideas are greatly appreicated...?????
Old 06-11-2004, 01:01 PM
aharman1116 aharman1116 is offline
Re: Surges at Idle....
ck intake gaskets and egr port and intake gaskets
Old 06-11-2004, 10:19 PM
rodeo02 rodeo02 is offline
Yep. this is most likely a bad intake manifold gasket.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 06-14-2004, 04:06 PM
Helmuth48's Avatar
G/luck
Joel
Thanks guys......I agree...since the gaskets were just recently replaced... it leads me to believe it is a leak!!!
I will have it checked out and let you know the results!!!!
Thanks again!!!!!!
Old 07-22-2004, 07:32 AM
rmarlins rmarlins is offline
Question
I have a 2000 Trooper and at times it stall and tries to shutt off the car but if I give it gas it does fine it doesn't doit all the time can you help me .
