Old 06-11-2004, 11:56 AM
josef_ josef_ is offline
89 dx hatchback - cuts out while driving
hi. i was wondering if aynone had any ideas about this.. my car cuts out (doesn't respond to pedal, doesnt accelerate, check engine light comes on) while accelerating after slowing down (stop lights, turns). if i do nothing it does, but if i keep on the gas it jerks back to accelerating after a second.. this was last night, and now it won't even turn over, just makes the noise like it's trying to but doesn't. anyone ever have similiar problem?
it just had an ignition switch changed because it would die after starting. before that, it wouldnt start at all, so the old alarm that was in it (i'm not the original owner) was taken out.
thanks for any help.. i really want to fix this, i love this car..
Old 06-11-2004, 12:05 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
It sounds like it could be your alternator/battery, but it also sounds like your not getting fuel to the engine, so it might be your fuel filter, or fuel pump, you should prolly switch out the main relay to, cause the more i think about it, it sounds like it may be the Main Relay
KoRnSaQ
Old 06-11-2004, 01:55 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
i would say fuel filter, you could try that because its really cheap at like $20 because i bought one yesterday but its always more expensive over here
Team Lonely Drivers
Old 06-11-2004, 02:10 PM
PhReAzE PhReAzE is offline
Send a message via MSN to PhReAzE
Re: 89 dx hatchback - cuts out while driving
you said it threw an engine code? cross reference the light on the ecu with a manual, or post it on here.
Evan
Old 06-11-2004, 03:09 PM
oh i didnt even notice that, what code is it ?
Team Lonely Drivers
Old 06-11-2004, 03:23 PM
Fewman Fewman is offline
Send a message via AIM to Fewman
It's always cheap and easy to check your rotor/dizzy!
Old 06-11-2004, 06:10 PM
hazcc280 hazcc280 is offline
my car does the samething....jerks when you hit the gas at a sertin RPM. mines throwing code 9(no1 piston pos.).everyone i talked to about it says its the sensor in the distributor thats burned out so the motor cant read where the no1 piston is so it missfires or someshit.
