Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-11-2004, 09:44 AM
OSUCowboy27 OSUCowboy27 is offline
No Spark at Coil.
My Crown Vic has a duraSpark ignition. All fuses good. Power to coil but No spark when cranking. Sometimes will start sparking and then car will run. Coil and module tested good. Replaced Module (brown grommet) and am going to replace coil. Is there a "pick-up" assembly or anything like that i should look for. Should i check ground and look for bad connections. Any suggestions would be greatly appreciated.
Old 06-11-2004, 11:03 PM
amo4387622 amo4387622 is offline
Re: No Spark at Coil.
what year Crown Vic?
Old 06-14-2004, 06:48 AM
It is a 1983 model with 5.0L fuel injected motor. I found that it was not pumping fuel and sparking when cranking so the only conclusion is a bad crank position sensor. I replaced it and car works fine and actually starts better.
