Go Back   Automotive Forums Car Chat > Mercedes-Benz > General Discussion
Old 06-11-2004, 09:47 AM
witchwone witchwone is offline
intermitent rattle in 300SD engine
The rattle sounds to me like it is deep in the motor but not steady. Not a rod knock and I would not think a wrist pin. It does not matter if the motor is under a load or not and it only does it after the motor oil has reached normal temp. no rattle when first started. It all most sounds like a loose timing chain, but with a spring/oil chain tensioner I dont see the rattle being intermitent any thought would be helpful
thanks
Old 06-11-2004, 02:59 PM
mechy1barry mechy1barry is offline
Re: intermitent rattle in 300SD engine
would think it is the timing chain slipper guides worn/ broken
Old 06-14-2004, 05:19 PM
SUMOBOY SUMOBOY is offline
What year 300SD is this? Are you sure the occasional noise is not in the turbo, trap oxidizer, or catalytic area?
If you don't have the toll money, can you still get to the light at the end of the tunnel?
Old 06-21-2004, 04:03 AM
1980 not sure of anything at this point. But the sound I am getting is internal.
