Old 06-11-2004, 03:05 AM
zboom86's Avatar
zboom86 zboom86 is offline
Send a message via AIM to zboom86
Headlight ?
I just installed new diamand cut Xeon H-4 lights in my 2nd gen Camaro. Then I noticed when i went to adjust them that the drivers side light is dimer than than the other. So I don't know what to do. Well they are tight but I need to find out how to fix this problem. Tommorrow All check all the wires with this diagram I got. Let me know what u think could cause this or how to fix it thanks.
Old 06-11-2004, 11:24 AM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: Headlight ?
are you sure that its dimmer?? maybe its just the way your looking at it cause at some angles one looks dimmer then the other on my bronco
Old 06-11-2004, 07:02 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: Headlight ?
Did you do the full wiring upgrade with the relays and all?? Ive heard a few people say that your entire headlight wiring system should be upgraded with heavier gauge wiring...
Read this and compare...
http://www.thirdgen.org/newdesign/te...tupgrade.shtml
Its for 3rd gens, but yours should be very similar
1991 Camaro Z28
Old 06-12-2004, 02:02 AM
zboom86's Avatar
Re: Headlight ?
That will healp a lot thanks man, and no its not how i'm looking at them trust me. All try to do all those up grades. The main one i want to do is the headlight plugs them selfs. I have brand new termanals and a interstate battery. Also I'm runing a 800watt amp and Bozkaa 100watt bass canyon and a pioneer deck so that don't help with out a capasiter. Thanks again
Old 06-12-2004, 09:56 AM
Re: Headlight ?
get a higher power alt. why your at it, cause my lights dim at night and my amp will cut off sometimes if im idleing, but mine is a 1600 watt and i have no capastor
Old 06-12-2004, 09:57 AM
Re: Re: Headlight ?
and hey man anythings possible
