Old 06-11-2004, 01:48 AM
CrzyMR2T CrzyMR2T is offline
motor oil companies
what motor oil company do you guys go with? have you actually seen actual proof of one motor oil company being better than the other? full syntec or regular? i heard that mobil 1 was good, but how would it do against other motor oil companis like castrol, and vavoline? i mean seriously, when it comes to over the counter oil that you can get at a local auto store, i think most of them are gonna have the same results if it has that api stamp of approval on it. some people stick with one company cause they think its slightly better than other companies, or because they say its better for their make, and model of car, but i seriously dont think it matters that much. anyone have their opinions, or proofs on this?
Old 06-11-2004, 04:03 AM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
I use Mobil 1, Amsoil, or Pennzoil, but really the most important things are that the oil is changed on time and the filter is good quality. Synthetics are more practical for turbocharged vehicles, but for a regular old street vehicle a good Dino oil will do just fine.
All of the test results I have seen were fishy at best and clearly biased at worst. In this case I generally go by word of mouth, since any data I have seen pertaining to this is generally garbage.
Beer tastes better upside down.
Old 06-11-2004, 04:58 AM
SaabJohan SaabJohan is offline
Re: motor oil companies
All oil companies have their own figures that show that they have the best oil...
In general a synthetic oil is better than a mineral one.
Old 06-11-2004, 05:18 PM
i heard some full syntetic oils werent exactly 100% syntetic, that some are more so than others, anyone know anything about this? would it really make any difference?
Old 06-15-2004, 09:12 AM
83-944 83-944 is offline
This is what your asking about CrazyMR2T
http://www.silkoleneoil.com/techtip4.htm
Synthetic oil IMO is fine for any vehicle. The oil leaks of higher milage engines switched to syn have been debated ad nauseum. Oil filter choice is just as debateable. Some love Fram, some hate fram, some love purolater, someones car blew up using purolater. Everybody found something on the internet supporting their claim and everyone has debunked the others claims. Personally Mobil 1 is available everywhere and has been used exclusively in our cars since the early 90's. Never had an engine fail or even any compression loss.
83 - Porsche 944 - daily driver
62 - VW Karmann Ghia - never ending restoration project
95 - Ford Mustang - wifes
Old 06-15-2004, 11:18 AM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
the use Penzoil Sythetic, synthetics generally dont break down as quickly as dino oil and work a little better, so im told. And i figured since i drive my car hard often that ill do this one little step to keep my engine alive longer.
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 06-15-2004, 09:15 PM
INF3RN0666 INF3RN0666 is offline
If you actually give a crap about all this synthetic oil shit, then pour in 1L with normal oil in your next oil change. That supposedly helps slightly if you can't afford synthetic all the time.
Old 06-16-2004, 01:56 AM
Oops, that's the wrong link. There are two synthetic motor oil types (in general). One is hydrocracked mineral oil ie Castrol Syntec, Quaker State Syn, Rotella T. Basically it breaks the larger molecules of oil into smaller even sized ones. It gives syn oil properties at a cheaper cost. Then there are "true" synthetic PAO oils. Refined from the beginning w/ small molecules. Also PAO oils are polarized, meaning they tend to stay in place after the engine stops. Much better for cold startups.
Small molecules = better smoother, even flow.
Old 06-17-2004, 09:24 AM
There are several "real" synthetic oils, to mention a few:
- Polyalphaolefins (PAO)
- Polyolesther
- Diesther
- Polyglycol
All these oils have different properties and are therefor suitable for different applications. What they have in common is that no one if them are made by refining mineral oil. This doens't mean that they are made from crude oil because they usually are. From crude oil we can refine certain hydrocarbons that we can make these oils from, the oils are then made by blendning the hydrocarbons needed and then let them undergo a chemical process, this can for example be addition polymerisation.
Old 06-17-2004, 01:14 PM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
change your oil within the manufacturers recommended intervals, and use the recommended grade, and never a fram filter, and it will return good service.
Old 06-17-2004, 08:07 PM
public's Avatar
public public is offline
Yeah, just change regularly. I always use Havoline or Valvoline. Sometimes I even use Fram filters Quaddriver. I got a cheap 89 cavalier with 300,000 miles on it. It still don't burn any oil. Just replaced a couple of seals and gaskets over the years.
Old 06-19-2004, 09:54 PM
replicant_008's Avatar
replicant_008 replicant_008 is offline
Viscosity - use the appropriate one for the vehicle and temperature range you are expecting to encounter. Using a fully synthetic oil with a viscosity of 15W-50 MAY NOT be appropriate for some engines particularly in cooler temperatures but better in higher temperatures.
Most of the synthetics are rated SG/CD (API) which indicates that they are better quality than say SE and SF.
Some oils are 'synthetic-fortified' ie they have a synthetic component added to the mineral oil base usually to assist with the oil's properties.
It's the usual case of most of the products at the higher price bracket will be better than the cheaper ones. Most of the manufacturers produce competitive products and it comes down to what you want to spend, what the application is (ie how you drive) and the engine requirements.
I have to use either a Shell or a Castrol Product in my engine because of the limited availability of oils where I am. They are the only two products that have the required viscosity for the conditions I have to travel in (temperature, load and type of motoring and the engine requirements) which dictate 0W - 30 SG.
I've tended to change the oil at half the recommended normal service interval because I am conscious of the mix of driving during the week contributing to dilution and sludge creation with lots of cold starts with short trips. In contrast, I also do extended touring with high loads in the weekends - and I am stuck with the OEM filters because of the powertrain warranty....
The only OEM engine manufacturer I am aware of that does NOT recommend synthetics was Mazda for its wankel-type rotary engines.
I resent being called a misogynist and a psychopath...
Contrary to popular belief I don't hate women I hate mankind in general and that makes me a misanthrope - Psychopaths engage in antisocial behaviour unknowingly - I have empathy and moral responsibility I just value my own personal needs more... that makes me a sociopath.
Old 06-20-2004, 05:22 AM
Did you know that's not true? The Magnuson-Moss Warranty Act says that a manufacturer cannot force you to use a particular filter or oil unless they provide it free of charge. They can recommend certain items, but cannot void your warranty unless you improperly perform the maintenance.
Old 06-20-2004, 03:32 PM
That would be true 83-944 if I lived in the US... which I don't.
Old 06-22-2004, 02:18 PM
Hemi99 Hemi99 is offline
Synthetic oils are the way to go. I run nothing but synthetic now after learning about them directly from the engineers at the oil companies. Synthetic oils are more refined (smaller) particles and do a good job of reducing friction due to their chemical makeup. These huge chemical chains that make up the synthetic portions cling to the important parts of your engine after it is shut off to reduce the wear & tear your engine takes on a cold start. Plus the fact that synthetics have a longer period before they start to break down surely helps your engine last for longer than on traditional oils.
