Old 06-10-2004, 08:52 PM
BlackShadowTSi BlackShadowTSi is offline
Send a message via AIM to BlackShadowTSi Send a message via MSN to BlackShadowTSi Send a message via Yahoo to BlackShadowTSi
Question Wich is the difference???
I need to know wich is the difference between a 16g and a 14b, wich one is better? how many psi pulls each?
Thanks
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Check My GS-T ==> AWD project
car's video: http://cssteam.com/gstx.wmv
At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm
Old 06-10-2004, 08:55 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
Re: Wich is the difference???
it's more a matter of flow. the 16g will flow more. because its bigger. the 14b is a tdo4h I believe and the 16 is tdo5
V8's are like tampons, every pussy needs one!
Old 06-10-2004, 08:57 PM
so you can tell me for the part # wich turbo I have?
the # is tdoh5 48178-0
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
16g is a bigger turbo therefore will give you more performance gain. different turbo alone shouldn't be confused with psi. a bigger and better turbo at a lower psi can performance better than a small stock T25 set at a higher psi. correct me if i am wrong.
06 Charger SRT-8 black.
Old 06-10-2004, 09:02 PM
Did you buy your car already modded, or did you get it stock? if you bought it stock, then you def don't have either turbo. but from your mod list, and this question, I'm guessing you bought it that way. so, I would say you have a 16g most likely. Just a guess though
Old 06-10-2004, 09:04 PM
i bought it that way and was pushing like 12 psi until I totaled it
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 06-11-2004, 12:45 AM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
most likely a 16g.
hey, BTW, do you still have those H&R springs?
Old 06-11-2004, 11:11 AM
yes i still have the h&r sprigns and the oem too.
i'm going to post the list with all i have in the dsm page as soon i have a minute. i still have the engine, and somebody is interested in the tranny and all the awd system
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
