| Let's get Technical! Discussion for hardcore in-depth motor heads! |
GSR or Ls
Should I try to get a GSR block to put my B16A head onto?...or should I do as someone was telling me and get the Ls block and put the B16A head onto it and pistons in it (is it even possible to do that)...I asked the same basic question on honda-tech but didnt get the answer I was looking for...
"Check that young man for nitrous"
12.428 @ 92.5 Mph Before, Now 12.000 @ 94.1 Mph On 1000ft Track Currently 4th in BHRA All Motor Class...Soon to be 2nd (I hope) ... Theres gonna be alotta slow singin, an flower bringin if I hear my car alarm start ringin ... |
Re: GSR or Ls
u probaly didnt get an answer from honda-tech. because that topic has probaly been covered there a million times. everything gets covered there. well first off wat kind of setup u gonna be doing turbo or N/A.
Re: GSR or Ls
All motor street/track car...
if it were me id probably go lsvtec
Re: GSR or Ls
for an all motor car. the GSR would be better because it has a higher compression ratio.
Re: GSR or Ls
i think you should just stick with a gsr block AND head and keep it simple.
88 Honda CRX Si - B16 90 Honda CRX Si - B20VTEC |
Re: GSR or Ls
yea that would probaly be the best choice.
Re: GSR or Ls
no no but I have a b16a and I can get either get a GSR block or a Ls block to put into my car...I dont want to swap full motors just blocks...
I was wondering if it was possible to put b16a pistons into the Ls block to raise the compression because then I would go with the Ls block because its supposed to be stronger than the GSR block... but if its not possible to do that with the Ls block I would just get the GSR block because its already got high compression and I wouldnt have to mess around with pistions...
Re: GSR or Ls
B16A Head - B18A/B18B Block - B18A/B18B Pistons = 9.77:1 Compression 1834 Displacement
B16A Head - B18C Block - B18C Pistons = 10.04:1 Compression 1797 Displacement B16A Head - B18A/B18B Block - B16A Pistons = 11.65:1 compression 1797 Displacement just ESTIMATES since jdm and usdm pistons yield different compression rates.
yes you can put b16 pistons on ls rods, and that with a b16 head, will yield a higher compression ratio then a stock gsr.
but watch out because if you do an lsvtec and run it with a b16 ecu, yoru going to run lean and probably experience a power loss. and you should atleast replace the rod bolts with some arp bolts because they are really weak. a vtec oil pump would also be a good idea. and idk if you would say that the ls block is stronger, i dont really think so. i think all of them are pretty equally strong. |
Re: GSR or Ls
Ok so i think im going to go with the Ls block or should I just build my B16A and see how much N/A power I can get out of that...
Re: GSR or Ls
http://www.bojangs.com/calculator/
Can any verify if this is accurate? |
ive seen 2 article on HCI where they built 2 b16s to over 200whp. theres someone on here that has like 214whp on his lsvtec. so you will make more power with the lsvtec but you gotta build it right so it lasts
that calculator seems pretty accurate, but i doubt anyone on here can verify that. maybe 1 or 2 but not all of them |
Re: Re: GSR or Ls
http://www.c-speedracing.com/howto/c...c/compcalc.php
99 [email protected] psi si- I voted for the Terminator for Gov. 95 HB- B16a2- SC34@12psi WTB: USDM B16a2 or B16a3 complete short block. pm is the key. FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me. |
