Old 06-10-2004, 04:35 PM
verdejt99 verdejt99 is offline
Code P0175
I keep getting this code whenever I am decelerating and making a left turn. Any ideas on what could cause it. It has happened twice so far. The truck still runs fine. Any info would be greatly appreciated.
Old 06-11-2004, 03:31 PM
mjgjr72 mjgjr72 is offline
Re: Code P0175
p0175 fuel trim system rich bank 2
bank 2 leaky injector
faulty ho2s bank 2
Old 06-13-2004, 08:48 PM
Code P0175
And it only happens when I'm running the A/C.
Old 06-15-2004, 12:47 AM
Code P0175
Well today I got the code again and I got the same code for bank 1. It seems to happen on sudden deceleration. I also forgot to mention that it has a rough idle. I was thinking of changing the plugs, pcv, air filter, possibly the EGR. Any thoughts would be greatly appreciated.
Old 06-15-2004, 07:35 AM
Re: Code P0175
although that would be good maintaince, i do not think it will fix the problem, it sounds like a leaky injector or injectors, maybe you can try running some injector cleaner through it.
Click To See My Ride 2000 Chevy Silverado LT Z71 K1500 ecsb, 6" suspention lift, 4.56 gaers, 315/75r16 bfg mt, radix supercharger, gibson headers and cat back, trasgo shift kit, aluminum servos, nelson tune
Old 06-16-2004, 09:51 PM
tstokes71 tstokes71 is offline
Angry I have the same code on my 97 Tahoe
I have the same code on my 97 Tahoe. Tune-up didn't help. I changed both oxygen sensors located before the converters and I still have a service code. Mine also idles rough with AC on. Someone told me to check the fuel pressure with key on but engine off. If low it may be a leaking regulator, but I haven't purchased a gauge to check it yet. Let me know if you fix yours and I'll do the same.
Tony
Old 06-20-2004, 11:06 AM
Rodie40's Avatar
Rodie40 Rodie40 is offline
Re: Code P0175
I have 2 codes for lean bank 1 and 2? Same deal? I have had work done on a pressure regulator around the tank area and fuel filter under manifold replaced? Didnt do a thing.
Old 06-29-2004, 08:23 PM
P0175 Code
Just checking to see if anybody has found the cure for this code. Mine is intermittent. I can't even get it to do it. Just when I figure out how to duplicate it, either it won't duplicate or happens when I least expect it.
