Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 06-10-2004, 03:18 PM
mon03 mon03 is offline
Question air suspension light
92 Towncar- After driving for about 1 hour, the Air Susp. warning light comes on.
-If you stop and shut the car off, and then switch it on again, the light goes away for about another half hour.
-If you dont stop, the 30amp fuse blows.
Any idea what the problem might be and/or how to fix it?
Thanks
Old 06-11-2004, 02:07 AM
ltdltc ltdltc is offline
Re: air suspension light
Thanks
Well it sounds like a short in the wiring.
Do you know how old the air compressor is, or how about the air springs?
If you can get your hand on a star scanner tool it would give you a trouble code when the AIR SUSP light goes off.
Richard
1995 Lincoln Town Car Signature Series
Past
1992 Lincoln Town Car Cartier Designer Series
1992 Lincoln Town Car Executive Series
1990 Lincoln Town Car
Old 06-11-2004, 01:18 PM
the compressor and springs are probably as old as the car is.
I was wondering if i could somehow isolate the problem to either the compressor or springs?
Thanks
Old 06-11-2004, 07:53 PM
Towncar's Avatar
Towncar Towncar is offline
Shut off the compressor, switch in the trunk, to see how long the springs hold their height.
If they start losing air quickly (rear end drooping) then you have a leak somewhere in the system and the compressor is most likely working overtime trying to keep up with the leak. This can cause the fuse to blow as the compressor overheats.
If your system stay pumped up with the compressor off, there's something wrong with the compressor or the wires that power it.
-Steven
1996 Town Car, Cartier
