Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 06-10-2004, 12:09 PM
thruhiker thruhiker is offline
Relay,actuator, or function switch?
My 95 bonneville is haveing HVAC problems. Last year the Temp. control actuator when up and I had to drop the Dash to replace it. The heat works great but now the A/C is giving me trouble. I had my Cousin an certifed and trustworthy Mech. top of the R12 because it was low and now it blows at 42 Degrees. My problem is that the air only comes from the floor and the Defoger at the same time. It will not come from the vents. I have the same problem if I use the heat. I have pulled out he Control unit and the wires are intact. I would like to exhaust all options before droping the dash. Any suggestions?
Old 06-10-2004, 02:11 PM
laff66 laff66 is offline
Just had the same problem. I tried everything, but could not get to the AC programmer on the passenger side under the dash. I finally took it to the dealer, and the programmer was the problem. They had to remove the dash (charged 3 hrs labor) and change it out. VERY expensive... but it fixed it.
Old 06-12-2004, 07:58 PM
markwb's Avatar
markwb markwb is offline
Re: Relay,actuator, or function switch?
It sounds as though a motor operated damper isn't shifting. Maybe the motor, or linkage?
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
Old 06-21-2004, 04:31 PM
fixed?
Pulled the dash and got to the vacumes. None of them were functioning with the dash controller so I pulled the programer. New programer $300 so I put the old one back in and used a coat hanger to hold open the vents. Jury rigged but it will work for now. I fixed the actuator that controls the damper last winter. Linkage and acturator are working fine. Thanks for the sugestions.
Dave
Old 06-21-2004, 05:51 PM
Ducky_Sota Ducky_Sota is offline
The *same* thing happens to my Bonneville. I found changing some of the vacuum hoses helped a lot, but still the vents don't push out any air. Wierd, but glad, to see others with the same problem - perhaps a Bonneville bug. Maybe I can try the coathanger route.
