Old 06-10-2004, 12:25 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
ZEX wet or dry
I know this has been discussed before, but i cant seem to find it. ok, I am just about done rebuilding my D16a6 and i am thinking about picking up a zex system. What i am wondering is which is better on the engine, running a dry shot or a wet shot.
KoRnSaQ
Old 06-10-2004, 02:20 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: ZEX wet or dry
Found some info herehttp://www.honda-tech.com/zerothread...postid=9918519
They seem to say that more than 75 shot of dry is not good without upgrading fuel supply (detonation) and the benefit of wet is it provides fuel in mixture, etc.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 06-10-2004, 02:36 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: ZEX wet or dry
Go with a zex dry system, easy to install, easy to use. if you want to stay with a 75 or under shot but if you plan on going with a bigger shot than that you should get a wet system. Even with the 75 shot dry system you should upgrade fuel pump, fuel rail, fpr, injector's to be safe, run colder plugs and run correct timing.
2002 Acura TL Type S
1991 Honda Crx Si
Old 06-10-2004, 02:40 PM
SiZ's Avatar
SiZ SiZ is offline
Re: ZEX wet or dry
Dry for a small shot.
civicHBSi91 - Are you using a 70 shot? I wanted nitrous so bad for a long time, but decided against it. Its so cheap for so good amount of power, but I was concerned about the saftey of it.
Old 06-10-2004, 02:52 PM
Re: ZEX wet or dry
55shot dry, denso plug's and 93 octane and other than the broken motor mount and bald tires it spices her up alot esp on top end.
75 shot some tires and that fixed motor mount and some time should put me low 13's high 12's depending on what tire's im on.
1991 Honda Crx Si
Old 06-11-2004, 09:59 AM
ya, i am prolly only goin to go with the 55 or 65 shot, so i guess i will go with th dry system, Thanks for the info
KoRnSaQ
Old 06-11-2004, 02:28 PM
crx91's Avatar
crx91 crx91 is offline
Re: ZEX wet or dry
Bottles are for babys.
Old 06-11-2004, 03:20 PM
Re: ZEX wet or dry
and your car is probably slow....so whats your point?
1991 Honda Crx Si
Old 06-11-2004, 03:48 PM
91civicDXdude's Avatar
Re: ZEX wet or dry
turbo that shit and have power all the time without paying to refill :P
Old 06-11-2004, 03:55 PM
Re: Re: ZEX wet or dry
That's the beauty, don't need power all the time.
and im still faster and on street tires
1991 Honda Crx Si
Old 06-11-2004, 03:56 PM
Re: ZEX wet or dry
2.38 60', burning the tires all the way into 3rd gear in the 1/8.......
what was your 1/8 and mph
Old 06-11-2004, 04:09 PM
Re: ZEX wet or dry
9.2@77mph with 2.2 on factory tire's, broken rear motor mount only trans side and engine side holding it together.
arent you using slicks of some sort? or road race tires?
your car is also lighter
1991 Honda Crx Si
Old 06-11-2004, 05:24 PM
Re: ZEX wet or dry
mph dictates speed, E.T. dictates traction. I had heavy 13" wire wheels with a horrible offset (fatties) with some Hoosier road race tires which totally suck ass. even with a big burnout i was getting no traction until halfway down the track
My video is on here somewhere....
Old 06-11-2004, 05:38 PM
Re: ZEX wet or dry
I have it saved.
maybe your launching too high, I launch at 2k basically a high idle...
i hear you car spin halfway through 2nd and catch
i should get a video of how much my engine moves without that back motor mount. its not actually broken...the bracket came off the car so its the bracket and motor mount in one just not connected to anything, i dont know if i was bolted down or welded down...gotta get that taken care of im sure that will help me out alot.
1991 Honda Crx Si
Old 06-11-2004, 07:12 PM
crx91's Avatar
Re: ZEX wet or dry
blah blah,bottles are for babys..just cuz you treat ur car like crap.fix it and get some good tires.
