Old 06-10-2004, 12:17 PM
tenaciousdugal30 tenaciousdugal30 is offline
Send a message via AIM to tenaciousdugal30
Angry Cooling Fan
After doing my water pump, stat, radiator and hoses, I've pretty much narrowed my cooling probs down to when my fan comes on, or a bad head gasket. If it is the gasket, it must not be mixing with the oil, probably just bad around a awater journal, or possibly even a clog in the system????? Other than that, I was gonna have my pal either hook my fan up to a toggle switch, or even to something like the stereo or something that is constanly on when the key is turned on. Think that'd be the easiest way out for now? Little help please, it seems like all you guys wanna do is talk, thirdgen.org gave me some real help with my clutch....
1970 Olds Cutlass S... Red w/ white stripes, 442 decklid
Rocket 350 bored .30 over
10.5:1 Pistons, Eagle Rods
Crank shaved 30 thou
Edelbrock Olds 350 Preformer intake
Shimmed oil pump
Big Valves, Shaved heads, Roller Rockers
Lunati strip Cam
Flowtech Headers
3" purple hornies header pipes w/ turndowns
Bosch Platinum 4 plugs w/ Accel 8.8 wires
TH350 Tranny
3.73 rear, looking for spool or some sort of posi....
Old 06-10-2004, 01:11 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
a bad head gasket will cause large bubbles in the radiator. the fan should come on at 220* i think. if it doesn't, change the switch in the passenger side of the engine. i priced one a few weeks ago and i think it was $18
Old 06-10-2004, 01:25 PM
85irocz 85irocz is offline
Send a message via AIM to 85irocz Send a message via Yahoo to 85irocz
My camaro had the same problem, and I changed the switch. The switch was 9$ at Autozone, but it never turned on the fan. I hooked up a toggle switch. You need the toggle switch, two female connector ends, and three wires. The toggle needs two hot wires- One going to the right fan clip, to the toggle, and then another from the toggle, to the positive battery terminal. The left fan clip is a ground- put it anywhere that is metal, like a frame bolt. Anything of that nature will work. When you start the car, turn on the fan, and when you turn off the car, turn the fan off. Overall, it's like 15$ to do it this way, but it bypasses everything and is very simple to do. Changing the switch requires removal of the alternator and belt, as well as working in an awkward place.
Hope it helps.
Old 06-10-2004, 01:33 PM
4onFloor's Avatar
you need a relay to do that or you'll burn up the switch.
there's a much much easier way of doing this tho. find the 2 relays on the fireway, one is for the fuel pump and one for the fan. find the one with the smaller orange wire and cut it or splice into it so you can run it through a switch to ground. this is much easier and cheaper. just need a cheap switch and bout 8ft of light gauge wire. and it uses the existing relay.
but i'd change the fan switch in the block first.
Old 06-10-2004, 04:16 PM
Dober89 Dober89 is offline
Re: Cooling Fan
Jumping out the cooling fan is gay. I just had to fix this problem on my iroc because the previous owner was too lazy to fix the problem correctly. As soon as I turned the key forward the fans would pop on before I even turned the engine over. I got the problem fixed and cleaned up the grounds and now I just need to replace the secondary fan because only the primary one works.
Old 06-11-2004, 12:12 AM
sykotic1 sykotic1 is offline
Re: Cooling Fan
is there any kind of switch that's automatic? it seems like everything people talk about you have to make sure you turn off when you shut down, i guess i always thought it worked with the ecm and you could get a fan switch that worked the same way stock except it turned on at lower temps. any ideas?
Old 06-11-2004, 11:52 AM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: Cooling Fan
havent burned mine up yet
Old 06-11-2004, 07:55 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: Re: Cooling Fan
You could try the Hypertech Thermomaster chip.. You can program it to turn your fans on at a lower temp. Then put a 160 degree thermostat in and you'l be set
1991 Camaro Z28
Old 06-11-2004, 07:56 PM
DaMoNe6969's Avatar
Re: Re: Cooling Fan
Are you sure it doesnt work?? My secondary fan wont turn on til the car is borderline overheating, or the A/C is on..
1991 Camaro Z28
Old 06-11-2004, 08:29 PM
Re: Cooling Fan
lol how do we go from a $15 piece at pep boys to the hypertech thing, so thats the cost of an automatic switch? now i wish i woulda laughed at everyone who told me to get the manual thing instead of riggin it up to run all the time. ill buy that for a dollar.
Old 06-11-2004, 09:09 PM
Re: Cooling Fan
Ya its toast the brushes and crap in the motor are junk.
