Old 06-10-2004, 09:16 AM
TBORCK TBORCK is offline
Send a message via AIM to TBORCK
Radio Trouble
I Bought A Honda Civic Ex And The Radio Will Light Up, And It Will Chang Stations But, You Cant Hear Anything. I First Thought That It Was Some Wiring Issues Due To The Fact That There Was A Lot Of Speaker Wire In The Truck, But I Looke At The Factory Speakers In The Truck And They Still Look Like They Are Hooked Up Please Help I Dont Kow Where To Start....
Old 06-10-2004, 04:33 PM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
Re: Radio Trouble
have you tried the volume button?
depending on if this is a cd or tape player have you tried inserting a cd or a tape?
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 06-10-2004, 09:50 PM
Re: Radio Trouble
don't you think that was the first thing i tried. yeah tried the volume. please some one help/ p.s what would you say would be the best air induction kit to put on a 2001 honda civic ex
Old 06-11-2004, 01:40 AM
Re: Radio Trouble
aem cold air intake gets my vote.
Old 06-11-2004, 07:23 AM
Icantgetno Icantgetno is offline
Re: Radio Trouble
if there are tons of speaker wires run I bet the speaker leads from the head do not run to the actual speakers, they were prolly run to an amp and then the speakers. an easy way to check this is to take the head unit out (or access the speaker leads anotherway) use a cordless drill battery (or other DC power source) and touch the speaker wires to the terminals this will cause static in the speakers and let you know they respond to signal. If that works from the head unit then the issue is in the head unit. If it doesnt work, try it at the speaker itself, If it works from there then the issue is the line between the head and the speaker, if not then its is likely the speakers. But all things considered from your description I suspect that the wires were run for an amp and the amp is not in the system any longer.
