Old 06-10-2004, 09:06 AM
jmy667 jmy667 is offline
Coolant fan problem
92 Camaro RS 3.1
My coolant fan will not come on. The fan will come on with the A/C or the heater running like it should. I pulled the plug from the temp sensor and started the engine. The fan came on immeadiately. This lead me to believe the sensor was bad so I replaced it. The fan still will not come on without the heater or A/C on. Any suggestions
Old 06-10-2004, 10:13 AM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: Coolant fan problem
is your car running hot?? what degree is the senser designed to let the fan come on?
Old 06-10-2004, 10:59 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
are you sure that your compressor clutch is engaging? If your AC system pressure is low it won't engage the compressor which won't start your ac system, which will not engage your fan.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 06-10-2004, 03:27 PM
Re: Re: Coolant fan problem
[quote=ridge_runner]is your car running hot?? what degree is the senser designed to let the fan come on?[/QUOT
If I do not turn the heater/ A/C on it will over heat because the fan will not turn on. I believe the fan is supposed to turn on at 213 degrees.
Old 06-11-2004, 11:14 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
relay?
Old 06-12-2004, 11:16 AM
idle.wild idle.wild is offline
have you tride replacing the the fan relay?
