Old 06-10-2004, 03:34 AM
boots03 boots03 is offline
Send a message via AIM to boots03 Send a message via Yahoo to boots03
Rear End
ok, how do i found out the Rear Gear in my iroc with out cracking the pumpkin cover??
~mike
Old 06-10-2004, 10:04 AM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: Rear End
jack that bad boy up, and get the axle code off the axle, go to the parts store and buy a hanyes manual (if you dont have one) and it will tell you in there
Old 06-10-2004, 10:05 AM
Re: Rear End
or just give me the axle code when you get it and ill tell ya what you got
Old 06-10-2004, 10:10 AM
Re: Rear End
o and i cant believe i left this out but the axle code is stamped on the front of the right axle housing, you might have to clean it up a little bit to be able to read it
Old 06-10-2004, 03:10 PM
Dober89 Dober89 is offline
Re: Rear End
If you have a 9 bolt there should be some tags on the left and right side of the cover held on by one of the bolts.
Old 06-10-2004, 03:25 PM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
Re: Rear End
a 9 bolt? do you mean 9 inch, but thats a ford rear. did they really make 9 bolts?
<<my engine
<<part of the front end during engine swap
other pictures of my car... click here
Old 06-10-2004, 05:50 PM
Re: Rear End
yes a 9 bolt. It was in 87-90 Irocs only I think. It was a Borg Warner unit made in Austrailia. Mine came with aluminum disc brake calipers. It had a larger ring gear then the 10 bolt at the time. I think the 10 bolt was 7.50" and the 9 bolt was 7.75". It was the performance unit put in the Irocs.
Old 06-10-2004, 05:55 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
my 90 rallysport has the 9 bolt borg warner rear end too.
Old 06-10-2004, 06:40 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Rear End
so does my 89 IROC, but also, look in the glove box, for the three digit build code that is GU# the number being between 2-6 that post it here, and i can tell you what gear ratio you are running, much cleaner tht way.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 06-10-2004, 07:01 PM
Re: Rear End
You mean the center console??? Everyone that gets in my car always wonders why theres no glove box.
Old 06-10-2004, 09:35 PM
Re: Rear End
It is GU6
Old 06-10-2004, 09:42 PM
Re: Rear End
damn that code is not in the book, you sure its the right one??
Old 06-10-2004, 09:46 PM
Re: Rear End
http://www.thirdgen.org/cgi-bin/rpo/index
GU6 : AXLE REAR, 3.42 RATIO
Old 06-10-2004, 09:48 PM
Re: Rear End
o...
Old 06-10-2004, 10:11 PM
89IROC&RS's Avatar
Re: Rear End
yupppers
