Old 06-10-2004, 01:52 AM
txdomino txdomino is offline
Send a message via MSN to txdomino
Directing A/C air.
I am having trouble redirecting the air on my A/C system. It seems to be stuck on blowing air through the vent and my feet. I change the dial to try to use the windshield defogger, for example, and nothing changes, the air still blows on my face instead of the windshield. What is the problem? Can I fix it myself and if so how do I?
Old 06-10-2004, 01:58 AM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
Re: Directing A/C air.
they get sticky too , eventually it will go to the right setting lol
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 06-12-2004, 04:40 PM
fluffybunny fluffybunny is offline
Send a message via AIM to fluffybunny
sounds like you have a bad actuator i dont have a diagram or anything on the 95's but its probably similar to my 96. the good news is the part probably isnt too expensive, the bad news is its alot of work from what i can tell. if you can find an electronic actuator on the exterior of the mode air box, or what ever its called. its a snap. but mine is showing as a vaccuum line....and its behind the heater core.... and that aint fuun to get to... check it out and try to find a picture or something that is more indepth on the procedure for replacing an air control actuator. good luck.
Old 06-13-2004, 02:20 PM
I got an idea TX , try changing the vent settings and all that while the car is off and not blowing and see if that moves the vent settings.
Old 06-14-2004, 09:12 AM
but if they are vaccuum operated they wont change....lest youre changing the hot/cold or the recuriculate/fresh air settings...... i thought he was talkin about the bilevel controls and defrost and stuff..........
Old 09-07-2004, 04:27 PM
95grand 95grand is offline
txdomino,
I am having the exact same problem with my 95 grand am. Did you ever figure out what the problem was?
Old 09-07-2004, 09:32 PM
Tom94gaGT Tom94gaGT is offline
Hey, I had the same problem on my 94 grand am.. they are controlled by a vaccum line (think of the hissing sound it maked when it was working when you changed it before), your line probably blew somewhere and thats why it wont change. When mine went last year my car was still under the used car warranty so i dont know how much it cost to get fixed but it shouldnt cost too much because it was in and out of the shop in less than an hour.
Old 09-08-2004, 10:43 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
you may just have a cracked vacuum line under the hood. My 91 grand prix did the same thing and it was the vacuum supply line that goes from the engine thru the firewall. They are made of plastic that gets brittle and cracks. If that's ok, then your mode actuator is bad and needs to be replaced. the mode valve actuator is on the drivers side of the heater box above the heater core, and will require you to stand on your head to replace. the AC Delco part # for a 95 is 15-71842 and retails for $10-$15. (Gm dealer part # is 01996778)
