Go Back   Automotive Forums Car Chat > Buick > Century
Old 06-09-2004, 09:24 PM
x_789 x_789 is offline
1990 3300 MPI Hard Start, Rough Idle, then Dies.
Hello all,
First post on this board. My brother-in-law has an old 1990 Century that is having some issues starting and poor idle. It currently is not driveable.
Basically he said a couple days ago they were driving it home and it started running really ruff and died then they ended up toeing it home. Well I went and had a look at it today it was throwing up two codes. A 21 for the TPS and a 43 for the ESTC or Electronic Spark Timing Control.
My brother in-law changed the TPS last night but wasn't sure how to adjust it. Its a three wire so I checked his Chilton and it said for that type just set it so the levers touch from the throttle and the TPS. I did that also tryed moving it around. This puppy don't want to start. So I tryed old tps wouldn't start either. Pulled a wire and checked was getting spark. So pulled a couple plugs. This thing has the Spark Control Module with the 3 coil packs sitting atop it. I tryed two plugs both on a diffrent coil. Each was black with soot and carbon. This thing is getting a ton of fuel and I looked at the airfilter its been backfiring into the airfilter a bit also before it decided not to run anymore.
Well after looking up codes I saw lots of peps saying control module so I pulled it had it tested. It was good after 6 tests in a row all good. So after reinstall started once very rough idle and rough running even when it would rev a bit. IT was sucking air in via Mass Airflow Sensor.
After we reinstalled the control module we hooked batt up again and it started and ran rough. I tryed moving module around a bit to see if it needed to be adjusted. Saw NO noticable improvments.
After that got a diffrent TPS code a 22 and the same 43
Not really sure where to go on this. Any ideas are appriciated..
Old 08-31-2004, 08:31 PM
rosebush rosebush is offline
codes
See if this will help you any,code 22 is tps voltage high,either misadjusted or bad connection most likely,code 43 is the esc (Electronic spark control circuit)which consists of the knock sensor.I would find the knock sensor.
Old 09-08-2005, 11:54 PM
dane_774 dane_774 is offline
sounds like the hamonic balancer is bad or the sensor behind it is. or the wires going to it rubbed thrugh
