Go Back   Automotive Forums Car Chat > Geo > General Discussion
Old 06-09-2004, 07:37 PM
rownus rownus is offline
Question 91 Tracker engine problem
My 91 Tracker has the 1.6L with about 163K on it. A couple of months ago I was coming home from work and pulled into my driveway when I got out and noticed that it was bleeding oil all over the place. I thought that the front crank bearing was shot so I pulled the engine. Upon inspection it looks like the oil pump is actually the faulty component. Now I'm trying to break loose the front timing sproket bolt but am having problems also holding the flywheel with a crowbar against the transmission mount. Since the engine is on my garage floor and moving all over the place, I was wondering if anyone has some trick to immobilizing the flywheel so I can break that bolt loose.
Old 06-10-2004, 02:55 AM
1995 geo tracker's Avatar
1995 geo tracker 1995 geo tracker is offline
go to your local auto parts store and pick up a flywheel holding tool , you might even be able to rent one
Old 06-10-2004, 07:09 PM
Re: 91 Tracker engine problem
Thanks. After posting the question I was checking out the manual (chiltons) and saw the holding tool. It was then when I realized what a dumb @ss I was for not looking at the manual in the first place.
Thanks for your input.
Old 06-10-2004, 07:17 PM
Question Upgrade
I also had a question about the 1.6L. In another thread someone wrote about swapping out a Suzuki Swift twin cam head with the stock head on the 1.6L. I wondered if anyone has ever done this and had any information on the timing belt routing or if there are any other issues with swapping them out. Any information would be greatly appreciated.
Thanks
Old 06-10-2004, 09:29 PM
98tracker's Avatar
98tracker 98tracker is offline
Send a message via Yahoo to 98tracker
Re: Upgrade
Thanks
if u do it yourself u need the head from the swift, a timing belt from a honda twin cam vtech, a standalone computer and new tracker headgasket and bigger injectors
