Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-09-2004, 07:37 PM
brokenLude brokenLude is offline
Crank stuck
ok, i have a 93 prelude si with 4ws and an h23, and i was putting a new timing belt on the other day, i finished up installing everything, started spinning the crank and it just stopped. so i took everything back off, figuring that i put a belt on wrong, then for kicks, i decided to spin the crank with no belts just to make sure. It still stopped, so i turned it backwards and it spins real nice and freely till it hits the same point where it procedes to just stop. I'm stumped, anybody got any ideas? it would be a huge help if i got some feedback on this.
Old 06-09-2004, 10:05 PM
Lude_03 Lude_03 is offline
Re: Crank stuck
did the timing belt break?
Old 06-10-2004, 12:58 AM
yea, i was cruizing along at like 40, the timing belt snapped, and bent 10 valves. I replaced the whole head because i got a super deal on a real clean one with the valves in it, it just seemed like a good idea. the head is installed correctly, my buddy who had done it a ton of times did it for me.
Old 06-10-2004, 11:49 AM
DJ Brady DJ Brady is offline
Send a message via AIM to DJ Brady Send a message via Yahoo to DJ Brady
Re: Crank stuck
I see where Lude's going though, it sounds like you've got a piston hitting a valve.
Old 06-10-2004, 12:50 PM
is there a way i can ceck that without pulling the head, because i dont really want to again.
Old 06-10-2004, 12:57 PM
Re: Crank stuck
wait, it only stops on one piston, and two go up and down at a time, wouldnt it stop it at two different points, and timing belt isnt on anymore, and the cams are at a point where they dont touch anything, ive rotated them like four times to different spots and spun the crank and each time it does the same thing
Old 06-10-2004, 01:08 PM
Re: Crank stuck
the cams will always have at least one valve open.... if you truly think it's a crank issue, pull the head and then spin the crank.
Old 06-10-2004, 05:36 PM
couldnt i just pop the cams out?
Old 06-10-2004, 06:26 PM
Re: Crank stuck
you could do that as well, the valves will spring closed. I figured it would be easier to pull the head than remove and then re insert the cams.
I'd still recommend pulling the head, if you've got a bent valve, it's not going to close and the piston's still going to hit.
I'm sure someone with more experience will have a better way, this is just my solution.
Old 06-11-2004, 12:51 AM
i'll try the cams first, then if that doesnt work, i'll pull the head.
Old 06-11-2004, 07:23 AM
Re: Crank stuck
good luck with it man.
Old 07-07-2004, 07:17 PM
Unhappy
ive been really busy lately, and i finally had an afternoon to myself, so i took the head off and suprise suprise, there are not only bent valves, but broken ones as well, i have a few pictures, when i figure out how to post them i will.
Old 07-07-2004, 08:20 PM
Phunyguy Phunyguy is offline
Send a message via AIM to Phunyguy Send a message via MSN to Phunyguy Send a message via Yahoo to Phunyguy
Re: Crank stuck
owch, sorry to hear that man gotta be careful with them timing belts!
Old 07-08-2004, 05:03 PM
Unhappy
Anybody got any info on f22b's, the DOHC one. I've read hp numbers from like 145 up to 160, and i can find those for like 400-500 less than a h23. if it indeed does have the same power, i may just scrap the h23 and go for that. and to whoever is going to respond with "get an h22" i dont have enough money, believe me, i've thought of it.
Old 07-09-2004, 01:34 AM
oh, the f series has iron sleeves i believe, which would make the engine work better with boost if i ever choose to go that route, so if the f22b does indeed have the same power as my h23a, then i think i may just swap them.
