Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-09-2004, 06:12 PM
nicks420 nicks420 is offline
gas smell in oil.
i have a 02 accord 4 cyl. Its been turbo charged now for 4-5 months.. I run only 5-6 psi. When i change my oil, it smells like gasoline a little bit. Anybody know why?
Old 06-09-2004, 11:59 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
do a compression test
Team Lonely Drivers
Old 06-10-2004, 01:18 PM
YellowITR479 YellowITR479 is offline
Re: gas smell in oil.
u put any additives in your oil?
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 06-10-2004, 05:16 PM
no additives. Just amsoil 5w-30.
Old 06-16-2004, 12:43 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
any car's oil will smell like gas a little if it isn't changed in a while. And since you have a turbo on your car, its getting a lot more fuel thatn normally. A little of that combustion is going to get past your rings and into your crankcase. Thats why you have a PCV valve. to get rid of the vapors, but regardless the process of the combustion gases getting by your rings will leave a gas like smell to the oil. and if your compression is low (compression check as suggested by civic killer) it will smell even more....
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 06-16-2004, 05:19 PM
that sounds like a good explanation. For some reason my pcv valve makes a loud humming noise. I just replaced it 4-5 months ago. Its been doing it since i put it in.
Old 06-18-2004, 01:26 PM
do not buy pcv valves from an auto parts store. They make one style valve and apply it to 5 different cars. each car has a specific pcv valve it needs. it really comes down to the pressure in the spring. go buy one from the dealer.
Old 06-18-2004, 06:23 PM
i did purchase mine from an auto parts store, i guess ill never do that again. They want like $25 for a genuine honda pcv valve. What do you think about this one.http://www.secureleadercom.com/exsto...nuStatus=block
