Old 06-09-2004, 04:47 PM
wew wew is offline
AC/Heat/Defroster Switch???
Hey...
Have a '97 Astro when AC/Heat switch is turned on to AC the air comes out the defrost and heat vents...Same when switced to outside air...The AC is working, you can hear it kick in and the air is cold, just can't get air to come out of dash panel vents...Obviously I am not a mechanic, anyone out there know the most likely cause and/or fix???
Thanks!!!
Old 06-10-2004, 10:55 AM
RonB RonB is offline
Sounds like you have a vacume leak. Check for a small tube (3/16 dia) that is broken. You may be able to hear it. If you find it, you can get a 6 inch length of larger tube and slide the smaller tube ends into it. I must fit snug, of course.
Old 06-13-2004, 05:57 PM
wew wew is offline
Re: AC/Heat/Defroster Switch???
Thanks a lot!...Will check it out as soon as I am able...And yes I have been noticing an odd sounding noise from under the hood, it is hard to describe, an airy tinny sound!
Old 06-16-2004, 01:43 AM
88bronk 88bronk is offline
Send a message via AIM to 88bronk Send a message via Yahoo to 88bronk
See 91 astro vacuum problems. igw
Old 06-16-2004, 10:25 PM
wew wew is offline
Thank you all so much!!!...Found broken vacuum tube and spliced it with a larger one...A/C now works as it should!!!
Old 08-11-2004, 12:12 AM
peve peve is offline
Where did you find the leak????
Newbie on the forum, found though Google
Where did you find the vacumn hose that was leaking, just took the whole dash apart today could not hear or feel a leak, look under the hood and I cannot see a vacumn hose to save my life.
Appreciate any help I can get.
Thanks,
PV
